i.MX8M mini and Android 8.1.0
1,704 次查看
territao
We are planning to use Android 8.1.0 on our product that uses the i.MX8M mini processor. The official supported Android version for i.MX8M is Android 11, on the other hand, because our software is only compatible with Android 8.1.0,  we need to bring up Android 8.1.0 on the product that uses i.MX8M mini processor.
The good news is, we downloaded the Android 8.1.0 BSP that NXP released for the i.MX8M mini processor, but it is an Alpha version, I'm wondering how many tests NXP had performed upon this version? Has any i.MX8M mini evaluation boards run Android 8.1.0 successfully?
1,667 次查看
nxf63675
1,691 次查看
nxf63675
Hi @territao,
The supported Android versions for the i.MX8MM starts on 9 GA releases, the Alpha/Beta releases that you have as you mentioned have limitations to know more download the documentation and check the release notes.
Alpha / Beta BSPs for Microprocessors | NXP Semiconductors
Israel.
1,680 次查看
territao
Hi @nxf63675 ,
Thanks a lot for your reply, the release notes for the ALPHA version (Android O8.1.0 ALPHA) are very helpful!
I noticed that there is a newer beta version (Android O8.1.0 Beta) available for i.MX8MMini, on the other hand, the release notes link is not valid, could you help to have a look?
Terri
1,668 次查看
nxf63675
Hi @territao,
Sure, please go to the next link and try it:
https://www.nxp.com/docs/en/supporting-information/android_o8.1.0_1.5.1_8mm-beta_docs.tar.gz
Israel.
