i.MX6q pop WLAN over PCIe problem
1,159 次查看
mannsikchung
Dear all, Please help me.
I'm trying to enable Broadcom WiFi on PICe of iMX6q pop type, source code base is yocto and using device tree.
But, I'm facing problem related Memory.
I enabled pcie in dts file by status = "okay".
And, changed ranges field as below to encreas enabling assign 16MB and others.
  ranges = <
  0x81000000 0 0          0x01f80000 0 0x00010000 /* downstream I/O */
  0x82000000 0 0x01000000 0x01000000 0 0x01f00000 /* non-prefetchable memory */
Now, I see below print out by "lsusb -v" command.
root@imx6qsabresd:~# lspci -v
00:00.0 PCI bridge: Synopsys, Inc. Device abcd (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 384
        Memory at 02800000 (32-bit, non-prefetchable) [size=1M]
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        Prefetchable memory behind bridge: 01000000-027fffff
        [virtual] Expansion ROM at 02900000 [disabled] [size=64K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable+ 64bit+
        Capabilities: [70] Express Root Port (Slot-), MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [140] Virtual Channel
        Kernel driver in use: pcieport
lspci: Unable to load libkmod resources: error -12
01:00.0 Multimedia controller: Broadcom Corporation Device 4354 (rev 02)
        Subsystem: Broadcom Corporation Device 4354
        Flags: fast devsel, IRQ 20
        Memory at 02100000 (64-bit, prefetchable) [disabled] [size=32K]
        Memory at 02000000 (64-bit, prefetchable) [disabled] [size=1M]
        Memory at 01000000 (64-bit, prefetchable) [disabled] [size=16M]
        Capabilities: [48] Power Management version 3
        Capabilities: [58] MSI: Enable- Count=1/16 Maskable- 64bit+
        Capabilities: [68] Vendor Specific Information: Len=44 <?>
        Capabilities: [ac] Express Endpoint, MSI 00
        Capabilities: [13c] Device Serial Number 00-00-00-00-00-00-00-00
        Capabilities: [150] Power Budgeting <?>
        Capabilities: [160] Virtual Channel
        Capabilities: [1b0] Latency Tolerance Reporting
        Capabilities: [220] #15
        Capabilities: [240] L1 PM Substates
First, why "lspci: Unable to load libkmod resources: error -12" is printed?
Second, why all of prefetchable Memory areas are [disabled]?
Please help me.
标签 (3)
标记 (1)
540 次查看
igorpadykov
Hi Mansik
seems it is not possible to increase 16MB as there is limitation on
address space of iMX6 PCIe as described at
PCIe BAR length limit
Regarding "libkmod" error this may be caused by incompatibility
versions: driver and kernel or other image components.
