Green dot-like garbage on iMX6 CSI BT1120 captured videos
jameszt
Dears,
         I am working on BT1120 (16bit data, parallel interface) capture development on iMX6Q CSI0 port, so far so good, but a lot of green garabge appears on the captured videos especially on gray background, pictures are as below, please help to advise, thanks a lot!!!
          DATA Source:  720P, YUV422(YUYV), CCIR progressive (BT1120 SDR mode);
BRs,
James
Labels (3)
joanxie
pls refer to the Support BT1120 progressive mode in Mx6Q , hope helpful for you.
jameszt
Thanks, this issue is confirmed to be HW cable unstable.
