For some reason our test i.MX6UL board is running slower than older i.MX28. Changing CCM_ANALOG_PLL_ARMn divider increases the performance slightly, but it's still about 3 times slower in integer calculcations.
What are correct clock register settings for full CPU speed (528MHz). Changing CACRR[ARM_PODF] divider to 0 causes CPU to hang. Is there some specific procedure for changing this bit?
Using U-Boot from Freescale git and vanilla kernel 4.4.2. U-boot is loaded via serial downloader, then Linux kernel is loaded from SD card and booted. Kernel CPU frequency scaling is disabled.
已解决! 转到解答。
It turned out that serial downloader boot happens at some lower frequency which is not switched up correctly in u-boot/kernel. Switching boot mode to boot from fuses solves this issue.
Hi J
procedure for setting set cpu frequency to 528 MHz one can find in
AN5170 sect.6.4.4. Video Playback: steps , sect.4.3 Dhrystone benchmark.
cache.freescale.com/files/32bit/doc/app_note/AN5170.pdf
For comparing performance of both processors one can run dhrystone using
arm document DAI0273A_dhrystone_benchmarking.pdf.
