Hi community,
Our partner will use i.MX6DL GPU for graphic operation with L3.0.35_4.1.0.
Then, they want to use a graphic library which has best performance.
Could you let me know which graphic library has best performance for the following functions?
(e.g. draw a line => DirectFB 2D acceleration library, alfa blending => OpenVG 1.1 library, etc...)
[Main functions]
Draw a line
Fill a picture with a color of user choice
Put a bitmap image
Use alfa blending
*3D graphic is not used.
Satoshi Shimoda
Solved! Go to Solution.
Hi Satoshi
i do not think that we have such performance characteristics.
chip
Hi Satoshi, please look at FTF WorkShop
"Introduction to OpenVG", it gives good examples of graphic libraries usage
http://cache.freescale.com/files/training/doc/ftf/2014/FTF-AUT-F0342.pdf
Hi chipexpert,
I checked the document, it is useful if we use OvenVG.
But I felt it does not mentioned about performance, doesn't it?
Could you give me advice what library has best performance to our functions?
Satoshi Shimoda
Hi Satoshi
chip
