Hi all,
I use the i.mMX53 SMD BSP and I want the NK support the chinese Font display, I try the all items of the bsp, but only Microsoft YaHei can be displayed, all of others(SimSun & NSimSun/SimSun-ExtB) can displayed by 口口, and in the Microsoft YaHei Font, the FootNotes displayed 口口 too, did i lost something about the Font items or others items?
By the way, i use the ClearType of the system, but it can not be work, Why?
[HKEY_LOCAL_MACHINE\System\GDI\Gamma]
"Gamma Value"=dword:5dc
[HKEY_LOCAL_MACHINE\System\GDI]
"FontLinkMethods"=dword:00000000
[HKEY_LOCAL_MACHINE\System\GDI\ClearTypeSettings]
"OffOnRotation"= dword:00000000
[HKEY_LOCAL_MACHINE\System\GDI\ClearType]
"ClearType"=dword:00000001
[HKEY_LOCAL_MACHINE\Software\Microsoft\Shell]
"NoClearType"=dword:00000000
Thanks for you help!
Solved! Go to Solution.
To support Chinese font, you need select the followed items from catalog:
Core OS -> CEBASE -> International -> Local Services
National Language Support (NLS)
Core OS -> CEBASE -> International -> Local Specific Support -> Chinese (Simplified)
Monotype Imaging AC3 Font Compression
Core OS -> CEBASE -> International -> Local Specific Support -> Chinese (Simplified) -> Fonts -> SimSun & NSimSun
SimSun & NSimSun (Subset 2_90)
Then open VS2008 menu "Project" -> IMX53-SMD-Mobility Properties...
In "Configiguration Properties" -> "Locale"; select as attached picture "Locate.png":
Hello Qiang_FSL,
Thanks for your help.
I try it, and find when i don't select the "Multilingual User Interface(MUI)", the display is ok(The Project-> properties is not set) . I do not konw the reason.
