how to enable Imx6 Quad booting Uboot.bin file option from Nor flash to SD card boot support
1,113 次查看
shanmugamsundar
   Currently iam working with imx6 quad sabrelite board ,default uboot.bin file boot from  NOR-FLASH  also kernel image  and rootfs files loaded in SD card.
Now i want to change u.boot file booting option  from NOR-FLASH to SD card and remaining kernel image  and rootfs files also same SD card only.
let me know the procedure for boot from imx6 Quad in SD card boot .
Thanks by,
Shan.
标签 (2)
1 回复
810 次查看
Rita_Wang
Hi Shanmugan,
To boot from SD card, you need to download uboot, kernel image and rootfs files to your board. When download finished , you can boot your board , then make sure to set right boot kernel commends in uboot.
Hope this can help you~~
Best Regards
Dan
