failed to enable l2 cache on imx6d
1,133 次查看
jiaojinxing
hello , i have ported sylixos(an rtos from china) to imx6d cpu which work at smp mode
i have a question, when i enable l2 cache, i write pl310 control register to 0x01, but i read it again, i found its value is 0x00, this mean i enable l2 cache failed,
why?
标签 (1)
标记 (2)
1 回复
954 次查看
AnsonHuang
Hi, jinxing
     Which register you wrote? The PL310's enable reg offset is 0x100, so you need to write 0x1 to 0xa02100.
