Description: | we try to use gplay to play mulltiple wmv files via playlist. |
gplay is in playlist repeat mode
repeat
===========press ">" and ""=========
after 20-100 times ">", the screen will turn into black and
wmv file will stop play.
the screen will turn into black after 20-100 (random) times Next. if debug is enabled, both hardware and software buffer cant be allocated in the stderr. (somthing like this : gst_v4l2_output_setup: Try to allocate 2 hw buffer failed!!) | |
MP4 playlist doesn't have this issue
Solved! Go to Solution.
Hi, I attached them again.
Hello All,
Sorry but I'm a new comer and don't know how to resolve the original problem with libglib-2.0.so.0.2200.1.zip and long_time_playback_dispose_element_4.1.0.patch.
Please tell me in detail. Thanks in advance.
Dear Carlos,
Thanks for your response.
The BSP and library version is: 【L3.0.35_4.1.0_130816_source.tar.gz】 and 【libfslmscodec-3.0.7-2.tar.gz】 【libfslmsparser-3.0.7-2.tar.gz】.
The wmv files: http://pan.baidu.com/s/1nt1Eg7v
Sorry for Chinese, please download all the 5 wmv file and repeat play them about 20-100 time. The screen will turn into black and gplay looks hang.
Here is debug log file:
/mnt/video/Rino - Juliette.wmv
Running time 0:00:03.303437500 render fps 0.000
0:20:36.113985316 [333m 4268 [00m 0x15760 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1469:mfw_gst_v4lsink_change_state: [00m
>>V4LSINK: State: 26
0:20:36.119648982 [333m 4268 [00m 0x15760 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1469:mfw_gst_v4lsink_change_state: [00m
>>V4LSINK: State: 17
Total rendered:0
0:20:36.120002649 [333m 4268 [00m 0x15760 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:712:mfw_gst_v4lsink_close: [00m Stream off.
0:20:36.120160649 [333m 4268 [00m 0x15760 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:739:mfw_gst_v4lsink_close: [00m close the fb0 device.
0:20:36.120253315 [333m 4268 [00m 0x15760 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:741:mfw_gst_v4lsink_close: [00m >>V4L SINK: Close the v4l device.
0:20:36.120530649 [333m 4268 [00m 0x15760 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1469:mfw_gst_v4lsink_change_state: [00m
>>V4LSINK: State: 9
[1;32m[--->FINALIZE aiurdemux
[0mfsl_player_stop()
fsl_player_set_media_location(): filename=/mnt/video/Rino - Juliette.wmv
[1;34mAiur: 3.0.7
Core: ASFPARSER_01.00.17 build on Jun 25 2013 10:17:36
mime: video/x-ms-asf
file: /usr/lib/imx-mm/parser/lib_asf_parser_arm11_elinux.so.3.1
[0m [1;34mContent Info:
[0m [1;34m URI:
[0m [1;34m file:///mnt/video/Rino - Juliette.wmv
[0m [1;34m Idx File:
[0m [1;34m /root/.aiur/.mnt.video.Rino - Juliette.wmv.aidx
[0m [1;34m Seekable : Yes
[0m [1;34m Size(byte): 17821977
[0m [1;34mMovie Info:
[0m [1;34m Live : No
[0m [1;34m Duration : 0:01:14.903000000
[0m [1;34m ReadMode : File
[0m [1;34m Track : 2
[0m [1;34mTrack 00 [video_000000] Enabled
[0m [1;34m Duration: 0:01:14.903000000
[0m [1;34m Language: und
[0m [1;34m Mime:
[0m [1;34m video/x-wmv, wmvversion=(int)2, format=(fourcc)WMV2, width=(int)720, height=(int
[0m [1;34m )576, framerate=(fraction)30/1, codec_data=(buffer)a7e8b480
[0m [1;33mWMV789_ARM11_00.01.02 build on Jul 17 2012 14:36:30.
[0m [1;32mMVW_GST_WMV789_PLUGIN 3.0.7 build on Sep 2 2014 14:35:29.
[0m [1;34mTrack 01 [audio_000000] Enabled
[0m [1;34m Mime:
[0m [1;34m audio/x-wma, wmaversion=(int)2, channels=(int)2, rate=(int)44100, block_align=(i
[0m [1;34m nt)743, depth=(int)16, bitrate=(int)128000, codec_data=(buffer)00000000010000000
[0m [1;34m 000
[0mFOUND GST_MESSAGE_TAG!
codec: Windows Media Audio V8
language code: und
bitrate: 128000
container format: ASF
video codec: wmv2
audio codec: Windows Media Audio V8
codec: wmv2
language code: und
[1;32mMFW_GST_V4LSINK_PLUGIN 3.0.7 build on Sep 2 2014 14:34:56.
[0m0:20:36.202851982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1469:mfw_gst_v4lsink_change_state: [00m
>>V4LSINK: State: 10
0:20:36.203933982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1469:mfw_gst_v4lsink_change_state: [00m
>>V4LSINK: State: 19
[1;34mBeep: 3.0.7
Core: WMA10 decoder Wrapper build on Mar 27 2013 16:34:03
mime: audio/x-wma, wmaversion = (int)[ 1, 4 ]
file: /usr/lib/imx-mm/audio-codec/wrap/lib_wma10d_wrap_arm12_elinux.so
[0m0:20:36.292370316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2004:mfw_gst_v4lsink_buffer_alloc: [00m crop_left_bypixel=32
0:20:36.292533982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2005:mfw_gst_v4lsink_buffer_alloc: [00m crop_top_by_pixel=32
0:20:36.292626982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2006:mfw_gst_v4lsink_buffer_alloc: [00m crop_right_bypixel=32
0:20:36.292715982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2007:mfw_gst_v4lsink_buffer_alloc: [00m crop_bottom_by_pixel=32
0:20:36.292802316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2017:mfw_gst_v4lsink_buffer_alloc: [00m aspectratio_n=1
0:20:36.292887316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2018:mfw_gst_v4lsink_buffer_alloc: [00m aspectratio_d=1
0:20:36.292970649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2020:mfw_gst_v4lsink_buffer_alloc: [00m Decoded Width = 784, Decoded Height = 640
0:20:36.293455982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2032:mfw_gst_v4lsink_buffer_alloc: [00m Decoder maximal reserved 12 buffers.
0:20:36.293559649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:2066:mfw_gst_v4lsink_buffer_alloc: [00m Decoder maximal support 66 buffers.
0:20:36.293774649 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 12 hw buffer failed!!
0:20:36.293879649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.293976982 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 11 hw buffer failed!!
0:20:36.294065649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.294159316 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 10 hw buffer failed!!
0:20:36.294246982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.294346982 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 9 hw buffer failed!!
0:20:36.294436982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.294531316 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 8 hw buffer failed!!
0:20:36.294618316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.294711649 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 7 hw buffer failed!!
0:20:36.294798649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.294892316 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 6 hw buffer failed!!
0:20:36.294978649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.295072982 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 5 hw buffer failed!!
0:20:36.295161316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.295254316 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 4 hw buffer failed!!
0:20:36.295341316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.295434316 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 3 hw buffer failed!!
0:20:36.295520982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.295614649 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:934:mfw_gst_v4l2_output_setup: [00m Try to allocate 2 hw buffer failed!!
0:20:36.295701649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:941:mfw_gst_v4l2_output_setup: [00m Fall down to allocate software buffer
0:20:36.295785982 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l.c:1022:mfw_gst_v4l2_mx6q_set_fmt: [00m Error in mfw_gst_v4lsink_output_setup
[1;33mCODEC: WMA10D_03.06.00_CORTEX-A8 build on Jul 19 2012 15:36:10.
number of channels: 2
bitrate: 128000
sampling frequency (Hz): 44100
audio codec: WMA version2, Standard, FormatTag:0x161
>>V4L_SINK: Actually buffer status:
hardware buffer : 0
software buffer : 0
0:20:36.295978982 [333m 4268 [00m 0x2c3fbde0 [31;01mERROR [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:692:mfw_gst_v4l2_buffer_init: [00m Failed to allocate buffer pool container
0:20:36.296110649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.296326649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
get GST_MESSAGE_ELEMENT playbin2-stream-changed, uri=(string)"file:///mnt/video/Rino\ -\ Juliette.wmv";
0:20:36.309505649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.309685982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.319668649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.319908649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.322817649 [333m 4268 [00m 0x31623228 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1469:mfw_gst_v4lsink_change_state: [00m
>>V4LSINK: State: 28
full screen size:1024x768
0:20:36.323009982 [333m 4268 [00m 0x31623228 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:1422:mfw_gst_v4l2_display_init: [00m Wrong display width information
0:20:36.323065982 [333m 4268 [00m 0x31623228 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l.c:1426:mfw_gst_v4l2_display_init: [00m Wrong display height information
0:20:36.323123316 [333m 4268 [00m 0x31623228 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l.c:788:mfw_gst_v4l2_get_crop_cap: [00m Capability:screen size:1024x768.
0:20:36.323173649 [333m 4268 [00m 0x31623228 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l.c:1339:mfw_gst_v4l2_set_crop: [00m [V4L Previous Display]: left=0, top=0, width=0, height=0
0:20:36.323225982 [333m 4268 [00m 0x31623228 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l.c:1343:mfw_gst_v4l2_set_crop: [00m [V4L Current Display]: left=0, top=0, width=1024, height=768
[1;31m[V4L Update Display]: left=0, top=0, width=1024, height=768
[0m0:20:36.323325316 [333m 4268 [00m 0x31623228 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l.c:1368:mfw_gst_v4l2_set_crop: [00m Set crop sucessfully
0:20:36.323378982 [333m 4268 [00m 0x31623228 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l.c:1376:mfw_gst_v4l2_set_crop: [00m Actual crop settings: 0, 0, 1024, 768
0:20:36.323568649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.333478316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.333673649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.342864982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.343052316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.352254649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.352501316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.373906982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.374010649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.374335982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.379021982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.379248649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.415164316 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.415316649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.415891316 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.423526649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.423827649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.468526982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.468690315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.469251649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.476924316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.477229982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.518520649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.518682315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.519235982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.526470316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.526794982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.567536649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.567692649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.568251649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.581384315 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.581678649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.618449315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.618611315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.619154649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.633378316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.633677982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.660858315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.661019315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.661590315 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.676171316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.676538982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.716550982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.716733316 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.717340982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
fsl_player_play()
[Playing (List Repeated)][Vol=01][00:00:00/00:01:14][fps:0]0:20:36.733313982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.733606982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.768208315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.768378315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.768979982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.786644649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.786938649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.811494315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.811656982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.812334316 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.819736315 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.820078315 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.868839315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.868995982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.869548982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.888774982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.889070649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.919524649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.919686982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.920282649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.941030649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.941328982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:36.963602316 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:36.963774649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:36.964363649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:36.986384649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:36.986741649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.015090982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.015252649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.015825649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.038365982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.038663649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.068321982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.068477649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.069051649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.091671982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.091969649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.119737649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.119902315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.120534315 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.142768316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.143112982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.169582649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.169743982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.170350315 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.177973649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.178279315 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.218535649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.218697982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.219253649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.241938649 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.242233649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.269039982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.269201315 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.269780982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.292458316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.292815316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.311417315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.311578982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.312190982 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.334330316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.334642649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.366954982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.367125649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.367747649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.375638316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.375941982 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.418249315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.418408649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.418975649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.441005982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.441359649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.461378982 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.461540649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.462147315 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.483900316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.484202649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.518527649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.518689982 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.519249649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.540260982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.540603649 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.568971315 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.569143649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.569732649 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.578323982 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.578696315 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
0:20:37.612981649 [333m 4268 [00m 0x31639e40 [32;01mINFO [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:70:mfw_gst_v4lsink_buffer_finalize: [00m Buffer 0 maybe dropped.
0:20:37.613143649 [333m 4268 [00m 0x31639e40 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:98:mfw_gst_v4lsink_buffer_finalize: [00m [1;31mmfw_gst_v4lsink_buffer_finalize: free software buffer [0m
0:20:37.613712316 [333m 4268 [00m 0x31639e40 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4lsink.c:1173:mfw_gst_v4lsink_show_frame: [00m Drop because no reserved hwbuffer0
0:20:37.637069316 [333m 4268 [00m 0x2c3fbde0 [33;01mWARN [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:435:mfw_gst_v4l2_new_buffer: [00m Try new buffer failed, ret 16 Device or resource busy queued 0
0:20:37.637370316 [333m 4268 [00m 0x2c3fbde0 [36mDEBUG [00m [00m mfw_v4lsink mfw_gst_v4l_buffer.c:440:mfw_gst_v4l2_new_buffer: [00m Finally assign a sw buffer from queue, left:0.
Please try this gplay to see if the issue still happen and let me know.
Hope this will be useful for you.
Best regards!
/Carlos
Dear Carlos,
Thanks for the response.
We will try the new verson of gplay and give the feedback as soon as possible.
BTW, would you please let us know what's the difference between these two versions of gplay.
Thanks for help very much.
Error message ruining the new version gplay:
[Stopped (List Repeated)][Vol=01][00:00:00/5124095:34:33][fps:0]
(<unknown>:2742): GStreamer-CRITICAL **:
Trying to dispose element streamsynchronizer0, but it is in PAUSED instead of the NULL state.
You need to explicitly set elements to the NULL state before
dropping the final reference, to allow them to clean up.
This problem may also be caused by a refcounting bug in the
application or some element.
(<unknown>:2742): GLib-GObject-CRITICAL **: g_object_ref: assertion `G_IS_OBJECT (object)' failed
Segmentation fault
jackmao Sep 16, 2014 7:07 PM (in response to Junping Mao)
Hi CarlosCasillas,
we have found some clue and get the new lib, please have a try
best regards
Jack
libglib-2.0.so.0.2200.1.zip910.3 KNo security policy violations found.The file was last scanned 3 days ago.
Hi jack jackmao
I cannot download the attached file libglib-2.0.so.0.2200.1.zip long_time_playback_dispose_element_4.1.0.patch.zip
It show "authzFailed" page when I click them.
would you help to make it public?
thank you so much.
HI jack ,Karina
thanks for kindly support!
jackmao please check the access of the information provided.
Hi Karina
I CANNOT access the link.
when I click the attached file link it show "authzFailed" page.
would you pls re-work that?karinavalencia
I have sent this additional information. I will let you know when having news.
Best regards!
/Carlos.
Could you please send me the video clip and script , and tell me what's the release you are using.
I will be waiting for your reply.
Best regards!
/Carlos.
We are reviewing your request internally, you will get an update soon.
Best regards!
/Carlos
