Where can I find a list of validated host distributions?
1,030 次查看
bricdesigns
I just downloaded everything that should be needed to build an image for the i.MX6 Automotive SABRE board.  Before I started developing any code, I wanted to make sure that everything was ready to go.  When I run 'bitbake fsl-image-x11', I get a warning:
WARNING: Host distribution "Ubuntu-14.10" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
I've searched around the forums and in a few places, folks have made comments about "Try this distribution" but I haven't found any pointers for a list of validated host distributions.  Does anyone have the list?  If not, does anyone know what the most recent validated Ubuntu version is?
Thanks!
标签 (2)
1 回复
820 次查看
SergioSolis
The recommended is Ubuntu 12.04 but I have also tried with Ubuntu 14.04
