I am using imx6 ul for the hardware design. The datasheet provides option for wdog1 (LCD_reset pad) pin. All the wdog stuff is generally done in software. Reference manual says wdog1 is a global watchdog signal. Is WDOG1_ANY pad is for detecting reset external signal to reset cpu? Is it optional in hardware design?
What does WDOG EXTERNAL SIGNAL mean? Are pin connection required to the chip from external source like reset IC?
解決済! 解決策の投稿を見る。
Hi Prabhat
WDOG1_ANY is global WDOG signal, it goes low if any of the WDOG(1,2,3)_B signals go low (assert).
I could not find "WDOG EXTERNAL SIGNAL", where did you find it, could you point document ?
Hi Igor,
Thanks for the quick reply. Sorry, I meant external signals under wdog mentioned in Reference Manual Pg 3633.
Hi Prabhat
