I'm trying to find the source code for UUC for creating an intramfs for MFGTool, does anyone here know where it is found?
Also, I can't find any information on how to build the initramfs that is used by MFGTool, is there any special requirements for it? Could the recovery.img from Android build be used (assuming UUC binary is included in it)?
解決済! 解決策の投稿を見る。
Hello Emil,
You can run the following command to get the UUC source code.
./ltib -m prep -p uuc.spec
The initramfs image can be generated by running "./ltib -m config" and choose "initramfs" at "Target Image Generation".
--- Target Image Generation
Options --->
--- Choose your root filesystem image type
Target image: (initramfs) --->
Peter
Thanks for the help. Was unable to build ltib on ubuntu, but I found the uuc source so that's fine.
Hi Emil,
Could you share me how to customize my own initramfs that can be used by MFGTool?
Best Regards
xixiguo
I believe there is a build target when using Yocto that will build the root filesystem used by MfgTool. I don't remember what it's called, you could search/ask the community here and someone probably knows.
Some starting points I found:
https://community.nxp.com/thread/384595
Freescale Yocto Project main page
good luck :smileyhappy:
Thank you Emil, I have solved my problem. I got the uuc source code from github. I customized my own rootfs. It works well.
Best Regards
xixiguo
That's great. Would you mind sharing with us where you found it?
thankx
You can find it in the BSP sources for ltib (pkgs/uuc-*tar.gz)
i.MX 6Quad, i.MX 6Dual, i.MX 6DualLite, i.MX 6Solo and i.MX 6Sololite Linux BSP Source Code Files
Hello Emil,
Options --->
Peter
