I am trying to build U-Boot for the IMX6 Solo Lite EVK with "make mx6slevk_config" and I get the following "error failed to create symbolic link `asm': Operation not supported" any ideas on how to fix it?
I am using a 32-bit Ubuntu VM
Solved! Go to Solution.
Apparently it has something to do with shared folders and my Ubuntu 12_04 VM. If I copy my files to my native VM Documents folder and do the make command the problem goes away.
