I am working on a imx6q custom board and using freescale linux kernel 3.14.52 .
I want to send and receive audio data from sgtl5000 codec connected to SSI interface of imx6 to an FPGA via EIM. What would be the best way to do that ?
Thanks and regards,
Sumish
解決済! 解決策の投稿を見る。
Hi Sumish
I think this is posiible, consider changing writing audio data to memory
circular buffer instead file.
Hi Sumish
one can check Chapter 28 Advanced Linux Sound Architecture (ALSA) System
on a Chip (ASoC) Sound Driver attached Linux Manual for linux sound subsystem description.
Data from fpga can be written to file, then played using examples in
imx-test (./mxc_sound_test) package
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
Hi igor,
Thanks a lot. To send continuous audio data from audio codec to fpga through EIM, can I use the same approach as you mentioned for the data received from fpga (for e.g. writing to a file first then send it to fpga)? Please note that we are sending/receiving continuous audio data.
Sumish
Hi Sumish
Thanks igor.
