Taking Qt application Remote
abhinandan1
I have a imx6 board upon whih i am running my qt application using eglfs platform plugin. I need suggestions for packages to add in my yocto build through which i can take my qt application remote. It would be better if qt application can be interacted with from my remote client.
I have tried vnc plugin available with Qt but it doesnt allow to interact with the application simultaneously through my touch display on board and through remote client.
Note: I am using thud release of yocto. I dont want to use x11.
hector_delgado
Hi @abhinandan1 ,
I hope you're doing great! What BSP version is your application running on? Also, what image did you build with Yocto (and what version of Yocto did you use)? Thank you.
Hector.
