Serial Download - Internal Boot
822件の閲覧回数
pauloisaia
Hi, I'm working with an IMXRT1050 and I need to make an image writing by the MCUXpresso Secure Provisioning software. To do this, I set the kit startup to serial download. After burning, the image will only run if I manually change boot to internal boot. I would like to know if it is possible to keep the boot in Serial Download, write the image and run the image without manually switching to internal boot
800件の閲覧回数
Omar_Anguiano
Hello
Hope you are well.
It is necessary to switch to internal boot to run the image.
There is some exception when you are using MCUXpresoo with a board. You can open a debug session while you are in serial download and the application runs while the debug session is open.
If you have more questions do not hesitate to ask me.
Omar
