How to connect USB type C to USB type B using HSIC without USB cable? Need a schematic diagram or interchip USB IC Details for to make the connection
Solved! Go to Solution.
Hi suracece27
for usage one can look at i.MX7ULP EVK, it has hsic connectors
Specification :
https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/imx-processors/23638/1/High Speed Inter-Chip_1_0 final.pdf
Dear Igorpady Kav,
I need to connect the same board with another custom made board which is having Cypress USB Controller https://www.cypress.com/file/140296/download
I need to connect both the boards using HSIC without having any USB receptacle.
I hope it's clear.
Need to connect both the boards without a USB connector with HSIC schematic reference diagram I am looking.
Thanks and Regards
Suresh
Hi suracece27
Specification :
Thanks a lot for your prompt reply. I will check and update the same..
