Pinmux modification at runtime
2,000 次查看
JeromeBaron
Hi everyone,
I'm working on a platform with a iMX28 that runs Linux. I would like to know if it's allowed to change the pinmux at runtime, while in the Linux.
My goal is to use a SPI port, program a device, then change those IO to GPIO after the programmation.
Can I do this? How?
Jerome
1,599 次查看
JeromeBaron
It appears the answer is a simple memory write to the CPU registers. I have found a small application(imxregs) in amadeus distribution to access those registers.
1,600 次查看
JeromeBaron
1,599 次查看
igorpadykov
Hi Jerome
seems not, since linux spi driver will own pins. To rmmod driver one needs
to be administrator with root permissions.
