hi nxp experts:
I'm now building a kernel-4.9.88 for mfgtools, i copy source code from yocto based on imx6sl-evk board, and make some changes( removing PMIC , adding usdhc4 for eMMC). u-boot is good for running, but kernel got stuck on the same place, please see my attached logs, and also attached my dts file, please point me where is wrong, did i cut down too much functions?
Best regards!
toot_hzf
Solved! Go to Solution.
i found the issues , for i removed the pmic from dts, when i uncomment pmic, it's ok now.....thanks
