I am starting to use Yocto but I have a lots of difficulties to understand how it works. Let's say I just want to modify u-boot, how should I proceed ?
I am following the Tasks which are published on this forum. I have found sources of u-boot extracted in build/tmp/work/imx6qsabresd-poky-linux-gnueabi and modified this files but when I recompile nothing happens.
Thanks !
Hi all. I'm Mariano Dominguez, Sorry that i'm re-open this question but i have the same problem and i don't know how to resolve it. I'm using Yocto 1.4 for I.MX 53. I'm compiling with bitbake. I want to make a change into u-boot-dey but then i can't re-compile. I put "bitbake u-boot-dey" but nothing happends, then i tried with "bitbake -f u-boot-dey", but still not working and finally i tried with "bitbake -c clean u-boot-dey" and then "bitbake u-boot-dey", this worked but when i put the flag "-c clean" all my changes was delete and then when compile, it genereted the new image but without my changes. How can i re-compile?
Mariano
When I hack U-Boot I never do it inside Yocto build system but I use a toolchain (which is build using Yocto) for it.
For toolchain build:
$: bitbake meta-toolchain
Using this you can build U-Boot byhand.
Once you did the need changes, considering you're making a product, you would do:
* make a company/product layer
* add a board file which is based on your development platform
* add a bbappend to apply the need patch for it
I hope it is helpful.
Hi all, sorry for re-asking this question but I'm trying to automate the my build using Yocto and also have the ability to replace SDK versions easily.
I have u-boot.patch file and bbappend that adds the patch to SRC_URI.
the bbappend file is located under my_layer/recipes/recipes-kernel/u-boot/
but for some reason bitbake -f u-boot does not take my changes.
I also tested my bbappend by over-writting the "do_listtasks" to echo to console.
when I place the bbappend in the same folder with the u-boot.bb it works
Can anyone assist?
Elad
It all depends on the u-boot recipe you are going to use.
In meta-fsl-arm we have:
OE-Core/Poky has:
I think you intend to bbappend u-boot-fslc.
Check this document: https://community.freescale.com/docs/DOC-95003
Leo
Well, in that case do a –c clean, then –c compile, then compare timestamps on all u-boot folders. Do you work on the folder with latest timestamps.
Leo
