Manufacturing tool for iMX
2,110件の閲覧回数
mathew_k_t
I wanna flash my emmc using manufacturing tool. But i found following difficulties in the manufacturing tool
  1. The downloaded file contains two directories with rootfs and without rootfs. Which I have to choose?
  2. How to install manufacturing tool, whether it requires any drivers?
  3. How to program emmc using Mfg tool?
3 返答(返信)
1,563件の閲覧回数
diegoadrian
Hello
The difference in the Manufacturing tool with rootfs and without rootfs, I explained you in your other community question.
Manufacturing tool doesn't need to be installed, is an executable file. You only need to run the script, but take note that you need to have the image in the correct folder. Otherwise, the script won't work.
To program the emmc, you only need to run the correct script that allows you to program the emmc.
Diego.
1,563件の閲覧回数
mathew_k_t
My mfg tool giving following error
can't find PMIC:PFUZE100
how to solve this.?
Also the default images in the mfgtool seems different from the images that I created(difference in name).
1,563件の閲覧回数
mathew_k_t
Thanks Diego,
What will be the boot setting(SW601,SW602) for iMX6ULL evk while
implementing manufacturing tool
On Wed, Jan 24, 2018 at 6:15 AM, diegoadrian <admin@community.nxp.com>
