I am working on i.mx53 quick sort board when i loaded kernel (uImage) on to the board using ethernet port for first time its showing full resolution after 1min its resolution is decreasing it came to black screen from the corners but not fully only little what will be the solution for this and here i am attaching some commands what i followed please find this
Original Attachment has been moved to: req.txt.zip
Original Attachment has been moved to: process.txt.zip
已解决! 转到解答。
Hi Arun Mondkar,
You system hangs because of mounting rootfs failure.
First make sure your host has exported the rootfs directory correctly.
%vi /etc/exports
edit this file by adding the export directory, for example:
/tools/rootfs *(rw,no_root_squash) save and exit
%exportfs -a
Secondly make sure your boot argument is set correctly.
MX6Q SABRESD U-Boot > setenv nfsroot /tools/rootfs
MX6Q SABRESD U-Boot > setenv bootargs_nfs 'setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot} v3,tcp'
Grace
Hi Arun Mondkar,
%vi /etc/exports
%exportfs -a
Grace
