I use this tool to test MX7D.The calibration can be tested success.But when I click the stress test,it will report error.
How I can solve this problem.Is it due to a mistake in my .ds file?
解決済! 解決策の投稿を見る。
Check carefully memory parameters settings in the init (.ds) script.
Results of calibration should be inserted in the script.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
