After switching to the Scarthgap release from Kirkstone, the kenrnel does not bind the DSI devices to each other and the DSI-HDMI-Bridge LT8912b is not working any more. The kernel switched from 5.15 to 6.6. Did any changes occur, that could cause this? I did not change the device tree (Custom Board).
This messages keep repeating infinitly:
[ 16.051534] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 16.059264] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 16.066360] [drm:drm_bridge_attach] *ERROR* failed to attach bridge /soc@0/bus@32c00000/mipi_dsi@32e10000 to encoder DSI-34: -517
[ 16.078073] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 16.086355] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 16.095315] lt8912 1-0048: failed to find dsi host
Solved! Go to Solution.
