MCIMX6Q5EYM10AE
MCIMX6Q5EYM10AE
474件の閲覧回数
RamakrishnaC
Hi team,
Please help...
Regarding empty flash wanted to check with NXP.... if JTAG will be detected if booting device is set to NOR flash and if its empty.
Thank you
5 返答(返信)
446件の閲覧回数
joanxie
pls share more detailed information, it's hard to give you suggestion based on so limited information you gave
443件の閲覧回数
RamakrishnaC
what details your looking for my side?
419件の閲覧回数
joanxie
did you flash the images to the nor flash by Jtag? I need to know how your operation steps, did you use your own design board? could you confirm if your HW design is total fine? pls share more detailed steps and your board information as you could
414件の閲覧回数
RamakrishnaC
Thank you.
Before that, i have one doubt i am taking very fresh board(No programming board). Shall i do  the first time program for NOR flash with JTAG connector debugger without serial downloader and without SD card.
402件の閲覧回数
joanxie
if your board doesn't have sd card interface and usb port, you can use Jtag to download images, if your board is fresh and without any images, you need flash by yourself before you start it, you can refer to the document as below
How to Use Trace32 to Run U-boot in the i.MX6Q SABRE Platform - NXP Community
