LTIB Image file size estimation and NAND Compression techniques.
926件の閲覧回数
VikramU_ng
Dear Support,
   is there an estimate available on the actual root image file sizes when LTIB is built for a specific architecture. I understand the PDK comes with 2GB NAND. Is there a rough guide on the kernel and the rootfs filesizes in advance?.
net@net-PC:~/Qt_imx257/ltib/rootfs$ ls -lh root*
net@net-PC:~/Qt_imx257/ltib/rootfs$ cd ..
net@net-PC:~/Qt_imx257/ltib$ ls -lh root*
-rw-r--r--  1 net net  15M 2011-09-13 21:56 rootfs.cramfs
lrwxrwxrwx  1 net net   15 2011-09-13 21:56 rootfs_image -> ./rootfs.cramfs
Is the current filesize seen for the Image correct?. I have been unable to find resources to compress/compare various image formats. Could someone provide any specific document on this?.
regards,
Vikram U
タグ(1)
799件の閲覧回数
VikramU_ng
A year later..
   i think the reliable guide is to identify the Base package - 300MB and then add the packages that need to go in.
800件の閲覧回数
VikramU_ng
A year later..
