Hi All,
I control LED driver (PCA9955B) using i.MX RT1064. After I set each register and LED1 pin is output. However waveform from LED1 pin is negative voltage(-0.24V). The power supply of PCA9955B is 3.3V. What are the possible causes of this phenomenon? It is unknown whether software or hardware.
<PCA9955B data sheet>
https://www.nxp.com/docs/en/data-sheet/PCA9955B.pdf
Hi Jose,
Thank you for your reply.
The cause was hardware. I'm sorry to have caused you trouble.
When you mentioned ‘waveform from LED1 pin is negative voltage(-0.24V)’, is this a negative spike or the voltage maintains at this level all the time?
I could use waveforms and schematics for a review.
Jose
