Issue in extracting the metadata information from audio file
1,046件の閲覧回数
srinivasanshanm
Dear Technical Support Team,
Am using L2.6.35_1.1.0_130130_source, I have a c-application as shown below and I like to read metadata from any audio file,
Am facing the one metadata issue, ie., if the song that does not contain any metadata is played , it shows the metadata contents of the previous song played, instead of showing no metadata.
Could you please kindly do the needful as early as possible in resolving the above issue i.e, if the song doesn't contains any metadata it should show empty tags instead of showing metadata contents of the previous songs played
Could you please let us know if there any other fsl apis that decides whether the audio file contains metadata information or not
getmetadat()
      fsl_player_metadata metadata;
      memset(&metadata,0,sizeof(fsl_player_metadata));
      pplayer->klass->get_property(pplayer, FSL_PLAYER_PROPERTY_METADATA, (void*)(&metadata));
                                         pplayer->klass->get_property(pplayer, FSL_PLAYER_PROPERTY_DURATION, (void*)(&totalDuration));
                                         pplayer->klass->get_property(pplayer, FSL_PLAYER_PROPERTY_ELAPSED, (void*)(&elapsedDuration));
Awaiting for your replies,
As am stuck with this issue from many days, please do the needful as early as possible,
Thanks in advance again
ラベル(2)
934件の閲覧回数
joanxie
SR 1-1315082041 is another issue for metadata, I think the patch I attached fixed your issue already,  for  how to show metadata information if the file don't have metadata.
6 返答(返信)
934件の閲覧回数
YixingKong
Senior Contributor IV
Srinivasan
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
934件の閲覧回数
srinivasanshanm
Still I have some issues discussion is going on in the SR# 1-1315082041
935件の閲覧回数
joanxie
934件の閲覧回数
srinivasanshanm
Thanks a lot for your support you can close this thread.
934件の閲覧回数
YixingKong
Sriniasan
Your SR# 1-1315082041 is in Customer Reply Period. You may get answer from there. Please note we are closing CRM system and using community as customer support tool. Please do not create duplicated request next time and oly in Community.
Yixing
934件の閲覧回数
joanxie
pls use the attachment.
