Hi all,
I need to port an algorithm to OpenCL for execution on the GC7000Lite GPU available on iMX8.
I could run execute and build a sample code on Windows MS Visual Studio 2013 environment using the vEmulator libs provided in the Vivante Toolkit.
I could not find suitable info describing the environment setup and the steps for building and executing OpenCL code on the target hardware like the 771-MCIMX8M-EVK evaluation board from NXP.
Could anyone here please shed some light on the same?
Any good references to the right documentation would be greatly helpful.
Thanks and regards
Vinay
Yes, Dinesh.
It was quite challenging.
You got to build and setup the build toolchain/SDK for the particular board by referring to the NXP Yocto Guide.
And then compile your C/C++ code using this SDK/toolchain.
Your OpenCL code will be compiled on the fly by the GPU driver [galcore] which is available on-board.
BRs
Hi Vinay
one can look at AN12060 Software ISP
https://www.nxp.com/docs/en/application-note/AN12060.pdf
Hi Igor,
Thank you very much for the quick response.
However, my application is not image processing and ISP based. My GPU application is more generic and mainly audio processing based.
Could you please share any available documentation that describes generic OpenCL application (non Image processing) development for GC7000Lite GPU?
Vinay
Hi Vinay
unfortunately I am not aware of specific i.MX8 OpenCL documentation
available for customers. Suggest to use extended support with Professional Services
