Is QSPI flash necessary for IMX8M+ with eMMC
826 次查看
balaecon
Hi Team,
We are designing a custom carrier board derived from IMX8M+ EVK reference design. We plan to have only the eMMC chip and not the QSPI flash (ref des "U4" in SCH-46881 EVK) in our design.
Processor Part planned for use: MIMX8ML8CVNKZAB
Our understanding is that QSPI chip is provided in the reference design for evaluation purposes and its possible to use only eMMC. Can you please let us know if our understanding is correct?
Is there anything else we would need to know from a hardware/firmware standpoint as far as QSPI removal is concerned?
标记 (4)
808 次查看
JorgeCas
Yes, that is correct.
You only need to remove it from device tree.
Best regards.
