Hi, I am using L4.19.35 official image.
But does it really support the LVDS to HDMI adapter card?
I attached the adapter card on port J7.
After boot, that card's red and yellow LED light, but there is no display on my HDMI screen. I use the fdt_file=fsl-imx8qm-mek.dtb.
On the other hand, native HDMI TX port (J6) using fsl-imx8qm-mek-hdmi.dtb is fine.
So is that card supported by default? How to use it?
Any help would be appreciated.
Here is the boot log:
U-Boot SPL 2019.04-4.19.35-1.1.0+g4d377539a1 (Oct 29 2019 - 14:34:58 +0000)
Normal Boot
Trying to boot from MMC2_2
Load image from MMC/SD 0x74000
UU-Boot 2019.04-4.19.35-1.1.0+g4d377539a1 (Oct 29 2019 - 14:34:58 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 27C
Model: Freescale i.MX8QM MEK
Board: iMX8QM MEK
Boot: SD1
DRAM: 5.8 GiB
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C0 0x51]
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... Run CMD11 1.8V switch
OK
In: serial
Out: serial
Err: serialBuildInfo:
- SCFW 550f3079, SECO-FW d7523fe8, IMX-MKIMAGE 1c2277b9, ATF 70fa7bc
- U-Boot 2019.04-4.19.35-1.1.0+g4d377539a1Run CMD11 1.8V switch
switch to partitions #0, OK
mmc1 is current device
flash target is MMC:1
Net:
Warning: ethernet@5b040000 (eth0) using random MAC address - 9e:dd:ac:46:d2:4c
eth0: ethernet@5b040000 [PRIME]
Warning: ethernet@5b050000 (eth1) using random MAC address - 96:3a:b4:0a:0f:aa
, eth1: ethernet@5b050000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
24263168 bytes read in 301 ms (76.9 MiB/s)
Booting from mmc ...
102464 bytes read in 7 ms (14 MiB/s)
Loading hdp firmware from 0x000000009c000000 offset 0x0000000000002000
Loading hdp firmware Complete
102464 bytes read in 8 ms (12.2 MiB/s)
Loading hdprx firmware from 0x000000009c800000 offset 0x0000000000002000
Loading hdp rx firmware Complete
98315 bytes read in 8 ms (11.7 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 0000000083000000, end 000000008301b00a
Disable i2c@3b230000, resource id 308 not owned
Disable can@5a8d0000, resource id 105 not owned
Disable can@5a8e0000, resource id 106 not owned
Disable can@5a8f0000, resource id 107 not owned
Disable gpt0@5d140000, resource id 207 not owned
Disable flexspi@5d120000, resource id 237 not owned
Disable intmux@37400000, resource id 289 not owned
Disable intmux@3b400000, resource id 309 not owned
/dma-controller@5a1f0000, 66816
/dma-controller@591F0000, 67660
/dma-controller@599F0000, 68704Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.35-1.1.0+g0f9917c56d59 (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #1 SMP PREEMPT Wed Oct 30 13:09:11 UTC 2019
[ 0.000000] Machine model: Freescale i.MX8QM MEK
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000096000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 28 MiB
[ 0.000000] OF: reserved mem: initialized node rpmsg_dma@90400000, compatible id shared-dma-pool
[ 0.000000] earlycon: lpuart32 at MMIO 0x000000005a060000 (options '')
[ 0.000000] bootconsole [lpuart32] enabled
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000097fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x97ff70c40-0x97ff726ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000097fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080200000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x0000000086400000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000094c00000-0x00000000fdffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000097fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000097fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x400 with crng_init=0
[ 0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s56728 r8192 d29288 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1479240
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: console=ttyLP0,115200 earlycon root=/dev/mmcblk1p2 rootwait rw video=HDMI-A-1:1280x720@60
[ 0.000000] software IO TLB: mapped [mem 0xf9fff000-0xfdfff000] (64MB)
[ 0.000000] Memory: 4837592K/6010880K available (14076K kernel code, 1806K rwdata, 6320K rodata, 1472K init, 431K bss, 190248K reserved, 983040K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.011307] Console: colour dummy device 80x25
[ 0.015477] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.025660] pid_max: default: 32768 minimum: 301
[ 0.030324] Security Framework initialized
[ 0.036961] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.045221] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.052078] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058915] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.090251] ASID allocator initialised with 32768 entries
[ 0.103334] rcu: Hierarchical SRCU implementation.
[ 0.117799] *****Initialized MU
[ 0.120617] ***** imx8_init_pm_domains *****
[ 0.126443] CPU identified as i.MX8QM, silicon rev 1.1
[ 0.133315] EFI services will not be available.
[ 0.145521] smp: Bringing up secondary CPUs ...
[ 0.183117] Detected VIPT I-cache on CPU1
[ 0.183147] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.183177] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.215127] Detected VIPT I-cache on CPU2
[ 0.215142] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.215157] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.247181] Detected VIPT I-cache on CPU3
[ 0.247195] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.247210] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.280935] CPU features: enabling workaround for EL2 vector hardening
[ 0.280941] Detected PIPT I-cache on CPU4
[ 0.280958] GICv3: CPU4: found redistributor 100 region 0:0x0000000051b80000
[ 0.280974] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.311280] Detected PIPT I-cache on CPU5
[ 0.311292] GICv3: CPU5: found redistributor 101 region 0:0x0000000051ba0000
[ 0.311304] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.311364] smp: Brought up 1 node, 6 CPUs
[ 0.408864] SMP: Total of 6 processors activated.
[ 0.413549] CPU features: detected: GIC system register CPU interface
[ 0.419989] CPU features: detected: 32-bit EL0 Support
[ 0.431346] CPU: All CPU(s) started at EL2
[ 0.435123] alternatives: patching kernel code
[ 0.440449] devtmpfs: initialized
[ 0.457094] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.466539] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.493423] pinctrl core: initialized pinctrl subsystem
[ 0.500489] DMI not present or invalid.
[ 0.504388] NET: Registered protocol family 16
[ 0.508952] audit: initializing netlink subsys (disabled)
[ 0.514102] audit: type=2000 audit(0.408:1): state=initialized audit_enabled=0 res=1
[ 0.521762] cpuidle: using governor menu
[ 0.526036] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.533105] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.545059] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.553184] Serial: AMBA PL011 UART driver
[ 0.557132] imx rpmsg driver is registered.
[ 0.563991] MU and Power domains initialized
[ 0.567931] ***** imx8qm_clocks_init *****
[ 0.575894] random: fast init done
[ 0.657877] imx8qm-pinctrl iomuxc: Invalid fsl,pins or pins property in node /iomuxc/imx8qm-mek/wifi_initgrp
[ 0.667382] imx8qm-pinctrl iomuxc: initialized IMX pinctrl driver
[ 0.705559] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.714420] mxs_phy 5b100000.usbphy: Linked as a consumer to regulator.0
[ 0.740418] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.747445] cryptd: max_cpu_qlen set to 1000
[ 0.760941] ACPI: Interpreter disabled.
[ 0.781733] vgaarb: loaded
[ 0.784407] SCSI subsystem initialized
[ 0.788281] usbcore: registered new interface driver usbfs
[ 0.793475] usbcore: registered new interface driver hub
[ 0.798788] usbcore: registered new device driver usb
[ 0.804115] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.812437] usb_phy_generic usbphynop1: Linked as a consumer to regulator.0
[ 0.819449] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.827974] usb_phy_generic usbphynop2: Linked as a consumer to regulator.0
[ 0.837060] i2c i2c-2: LPI2C adapter registered
[ 0.842437] i2c i2c-3: LPI2C adapter registered
[ 0.847693] max732x 4-0068: failed reading
[ 0.851468] max732x: probe of 4-0068 failed with error -5
[ 0.857115] i2c i2c-4: LPI2C adapter registered
[ 0.862229] i2c i2c-5: LPI2C adapter registered
[ 0.867319] i2c i2c-6: LPI2C adapter registered
[ 0.872409] i2c i2c-7: LPI2C adapter registered
[ 0.877539] i2c i2c-8: LPI2C adapter registered
[ 0.882673] i2c i2c-9: LPI2C adapter registered
[ 0.888713] media: Linux media interface: v0.10
[ 0.892944] videodev: Linux video capture interface: v2.00
[ 0.898659] pps_core: LinuxPPS API ver. 1 registered
[ 0.903331] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.912470] PTP clock support registered
[ 0.917872] Advanced Linux Sound Architecture Driver Initialized.
[ 0.924206] Bluetooth: Core ver 2.22
[ 0.927461] NET: Registered protocol family 31
[ 0.931869] Bluetooth: HCI device and connection manager initialized
[ 0.938219] Bluetooth: HCI socket layer initialized
[ 0.943081] Bluetooth: L2CAP socket layer initialized
[ 0.948136] Bluetooth: SCO socket layer initialized
[ 0.953379] clocksource: Switched to clocksource arch_sys_counter
[ 0.959316] VFS: Disk quotas dquot_6.6.0
[ 0.963091] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.970047] pnp: PnP ACPI: disabled
[ 0.979361] NET: Registered protocol family 2
[ 0.984030] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.991665] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.999274] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.006453] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.012779] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.018869] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.025487] NET: Registered protocol family 1
[ 1.030177] RPC: Registered named UNIX socket transport module.
[ 1.035757] RPC: Registered udp transport module.
[ 1.040447] RPC: Registered tcp transport module.
[ 1.045136] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.052782] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.060926] kvm [1]: 8-bit VMID
[ 1.064288] kvm [1]: vgic-v2@52020000
[ 1.067633] kvm [1]: GIC system register CPU interface enabled
[ 1.073531] kvm [1]: vgic interrupt IRQ1
[ 1.077458] kvm [1]: Hyp mode initialized successfully
[ 1.085462] Initialise system trusted keyrings
[ 1.089661] workingset: timestamp_bits=44 max_order=21 bucket_order=0
[ 1.101727] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.107800] NFS: Registering the id_resolver key type
[ 1.112526] Key type id_resolver registered
[ 1.116677] Key type id_legacy registered
[ 1.120680] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.127379] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.134122] 9p: Installing v9fs 9p2000 file system support
[ 1.139346] pstore: using deflate compression
[ 1.147930] Key type asymmetric registered
[ 1.151693] Asymmetric key parser 'x509' registered
[ 1.156600] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.163946] io scheduler noop registered
[ 1.167984] io scheduler cfq registered (default)
[ 1.172544] io scheduler mq-deadline registered
[ 1.177063] io scheduler kyber registered
[ 1.203220] imx6q-pcie 5f000000.pcie: Linked as a consumer to regulator.1
[ 1.209741] imx6q-pcie 5f000000.pcie: No cache used with register defaults set!
[ 1.217046] imx6q-pcie 5f000000.pcie: host bridge /hsio/pcie@5f000000 ranges:
[ 1.224102] imx6q-pcie 5f000000.pcie: No bus range found for /hsio/pcie@5f000000, using [bus 00-ff]
[ 1.233313] imx6q-pcie 5f000000.pcie: IO 0x6ff80000..0x6ff8ffff -> 0x00000000
[ 1.240698] imx6q-pcie 5f000000.pcie: MEM 0x60000000..0x6fefffff -> 0x60000000
[ 1.494874] imx6q-pcie 5f000000.pcie: phy link never came up
[ 1.500200] imx6q-pcie 5f000000.pcie: failed to initialize host
[ 1.506096] imx6q-pcie 5f000000.pcie: unable to add pcie port.
[ 1.512067] imx6q-pcie 5f000000.pcie: Dropping the link to regulator.1
[ 1.518498] imx6q-pcie: probe of 5f000000.pcie failed with error -110
[ 1.525949] pwm-backlight lvds_backlight@0: lvds_backlight@0 supply power not found, using dummy regulator
[ 1.535340] pwm-backlight lvds_backlight@0: Linked as a consumer to regulator.0
[ 1.543821] pwm-backlight lvds_backlight@1: lvds_backlight@1 supply power not found, using dummy regulator
[ 1.553171] pwm-backlight lvds_backlight@1: Linked as a consumer to regulator.0
[ 1.571527] Bus freq driver module loaded
[ 1.575674] seco_mu 31560000.mu: current SECO FW do not support SHE
[ 1.581640] seco_mu: probe of 31560000.mu failed with error -524
[ 1.587683] seco_mu 31570000.mu: current SECO FW do not support SHE
[ 1.593866] seco_mu: probe of 31570000.mu failed with error -524
[ 1.599923] seco_mu 31580000.mu: current SECO FW do not support SHE
[ 1.606113] seco_mu: probe of 31580000.mu failed with error -524
[ 1.621461] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.630555] SuperH (H)SCI(F) driver initialized
[ 1.636045] msm_serial: driver initialized
[ 1.640649] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 70, base_baud = 5000000) is a FSL_LPUAR[ 1.651814] console [ttyLP0] enabled
[ 1.658798] bootconsole [lpuart32] disabled
[ 1.667376] fsl-lpuart 5a060000.serial: NO DMA tx channel, run at cpu mode
[ 1.674261] fsl-lpuart 5a060000.serial: NO DMA rx channel, run at cpu mode
[ 1.681627] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 71, base_baud = 5000000) is a FSL_LPUART
[ 1.691469] imx8qm-pinctrl iomuxc: pin_config_set op failed for pin 13
[ 1.698013] fsl-lpuart 5a090000.serial: Error applying setting, reverse things back
[ 1.705956] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 72, base_baud = 5000000) is a FSL_LPUART
[ 1.718387] arm-smmu 51400000.iommu: probing hardware configuration...
[ 1.724925] arm-smmu 51400000.iommu: SMMUv2 with:
[ 1.729643] arm-smmu 51400000.iommu: stage 1 translation
[ 1.735052] arm-smmu 51400000.iommu: stage 2 translation
[ 1.740453] arm-smmu 51400000.iommu: nested translation
[ 1.745775] arm-smmu 51400000.iommu: stream matching with 32 register groups
[ 1.752925] arm-smmu 51400000.iommu: 32 context banks (0 stage-2 only)
[ 1.759555] arm-smmu 51400000.iommu: Supported page sizes: 0x61311000
[ 1.766094] arm-smmu 51400000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 1.772635] arm-smmu 51400000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 1.823057] imx8-dpr-channel 560d0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.831214] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56050000.prg
[ 1.839240] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.847384] imx8-dpr-channel 560f0000.dpr-channel: Linked as a consumer to 56060000.prg
[ 1.857546] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56070000.prg
[ 1.865571] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56080000.prg
[ 1.875695] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 56090000.prg
[ 1.883719] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 560a0000.prg
[ 1.893844] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560b0000.prg
[ 1.901869] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560c0000.prg
[ 1.912047] imx8-dpr-channel 570d0000.dpr-channel: Linked as a consumer to 57040000.prg
[ 1.920193] imx8-dpr-channel 570e0000.dpr-channel: Linked as a consumer to 57050000.prg
[ 1.928215] imx8-dpr-channel 570e0000.dpr-channel: Linked as a consumer to 57040000.prg
[ 1.936376] imx8-dpr-channel 570f0000.dpr-channel: Linked as a consumer to 57060000.prg
[ 1.946533] imx8-dpr-channel 57100000.dpr-channel: Linked as a consumer to 57070000.prg
[ 1.954560] imx8-dpr-channel 57100000.dpr-channel: Linked as a consumer to 57080000.prg
[ 1.964687] imx8-dpr-channel 57110000.dpr-channel: Linked as a consumer to 57090000.prg
[ 1.972704] imx8-dpr-channel 57110000.dpr-channel: Linked as a consumer to 570a0000.prg
[ 1.982833] imx8-dpr-channel 57120000.dpr-channel: Linked as a consumer to 570b0000.prg
[ 1.990853] imx8-dpr-channel 57120000.dpr-channel: Linked as a consumer to 570c0000.prg
[ 2.002352] dpu-core 56180000.dpu: Linked as a consumer to 56100000.dpr-channel
[ 2.009686] dpu-core 56180000.dpu: Linked as a consumer to 56110000.dpr-channel
[ 2.017010] dpu-core 56180000.dpu: Linked as a consumer to 560f0000.dpr-channel
[ 2.024336] dpu-core 56180000.dpu: Linked as a consumer to 56120000.dpr-channel
[ 2.031655] dpu-core 56180000.dpu: Linked as a consumer to 56020000.pixel-combiner
[ 2.040007] dpu-core 56180000.dpu: driver probed
[ 2.045424] dpu-core 57180000.dpu: Linked as a consumer to 57100000.dpr-channel
[ 2.052750] dpu-core 57180000.dpu: Linked as a consumer to 57110000.dpr-channel
[ 2.060076] dpu-core 57180000.dpu: Linked as a consumer to 570f0000.dpr-channel
[ 2.067396] dpu-core 57180000.dpu: Linked as a consumer to 57120000.dpr-channel
[ 2.074724] dpu-core 57180000.dpu: Linked as a consumer to 57020000.pixel-combiner
[ 2.082854] dpu-core 57180000.dpu: driver probed
[ 2.091378] adv7511 2-003d: 2-003d supply avdd not found, using dummy regulator
[ 2.098742] adv7511 2-003d: Linked as a consumer to regulator.0
[ 2.104674] adv7511 2-003d: 2-003d supply dvdd not found, using dummy regulator
[ 2.112025] adv7511 2-003d: 2-003d supply pvdd not found, using dummy regulator
[ 2.119372] adv7511 2-003d: 2-003d supply a2vdd not found, using dummy regulator
[ 2.126838] adv7511 2-003d: 2-003d supply v3p3 not found, using dummy regulator
[ 2.134189] adv7511 2-003d: 2-003d supply v1p2 not found, using dummy regulator
[ 2.141984] adv7511 2-003d: Probe failed. Remote port 'mipi_dsi_bridge@56228000' disabled
[ 2.150344] adv7511 3-003d: 3-003d supply avdd not found, using dummy regulator
[ 2.157834] adv7511 3-003d: Linked as a consumer to regulator.0
[ 2.163769] adv7511 3-003d: 3-003d supply dvdd not found, using dummy regulator
[ 2.171123] adv7511 3-003d: 3-003d supply pvdd not found, using dummy regulator
[ 2.178475] adv7511 3-003d: 3-003d supply a2vdd not found, using dummy regulator
[ 2.185906] adv7511 3-003d: 3-003d supply v3p3 not found, using dummy regulator
[ 2.193256] adv7511 3-003d: 3-003d supply v1p2 not found, using dummy regulator
[ 2.201020] adv7511 3-003d: Probe failed. Remote port 'mipi_dsi_bridge@57228000' disabled
[ 3.217508] it6263 6-004c: Probe failed. Remote port 'lvds-channel@0' disabled
[ 3.225271] it6263 7-004c: Probe failed. Remote port 'lvds-channel@0' disabled
[ 3.235651] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.242351] [drm] No driver support for vblank timestamp query.
[ 3.248380] dpu-core 56180000.dpu: Linked as a consumer to 560d0000.dpr-channel
[ 3.255703] dpu-core 56180000.dpu: Linked as a consumer to 560e0000.dpr-channel
[ 3.263037] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.271179] dpu-core 57180000.dpu: Linked as a consumer to 570d0000.dpr-channel
[ 3.278510] dpu-core 57180000.dpu: Linked as a consumer to 570e0000.dpr-channel
[ 3.285837] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.294438] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.302073] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.310036] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.317689] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.325018] nwl_dsi-imx mipi_dsi@56228000: No bridge found, skipping encoder creation
[ 3.332862] imx-drm display-subsystem: bound mipi_dsi@56228000 (ops imx_nwl_dsi_component_ops)
[ 3.341530] nwl_dsi-imx mipi_dsi@57228000: No bridge found, skipping encoder creation
[ 3.349379] imx-drm display-subsystem: bound mipi_dsi@57228000 (ops imx_nwl_dsi_component_ops)
[ 3.358044] [drm] Cannot find any crtc or sizes
[ 3.363071] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 3.377943] loop: module loaded
[ 3.382071] input: fxos8700 as /devices/platform/5a800000.i2c/i2c-4/4-001e/input/input0
[ 3.392049] fxos8700 device driver probe successfully
[ 3.392792] input: fxas2100x as /devices/platform/5a800000.i2c/i2c-4/4-0020/input/input1
[ 3.406618] fxas2100x 4-0020: fxas2100x device driver probe successfully
[ 3.416208] iommu: Adding device 5f020000.sata to group 0
[ 3.425031] ahci-imx 5f020000.sata: imx8qm sata only supports 32bit dma.
[ 3.431747] ahci-imx 5f020000.sata: ext_osc is not specified.
[ 3.437499] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 3.444344] ahci-imx 5f020000.sata: No cache used with register defaults set!
[ 3.452345] ahci-imx 5f020000.sata: external osc is used.
[ 3.460566] ahci-imx 5f020000.sata: no ahb clock.
[ 3.465342] ahci-imx 5f020000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 3.474228] ahci-imx 5f020000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sadm sds apst
[ 3.485021] scsi host0: ahci-imx
[ 3.488548] ata1: SATA max UDMA/133 mmio [mem 0x5f020000-0x5f02ffff] port 0x100 irq 145
[ 3.499147] slram: not enough parameters.
[ 3.507531] libphy: Fixed MDIO Bus: probed
[ 3.511963] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 3.517945] tun: Universal TUN/TAP device driver, 1.6
[ 3.523169] CAN device driver interface
[ 3.530118] iommu: Adding device 5b040000.ethernet to group 1
[ 3.536473] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, using dummy regulator
[ 3.545322] fec 5b040000.ethernet: Linked as a consumer to regulator.0
[ 3.552185] pps pps0: new PPS source ptp0
[ 3.556768] fec 5b040000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 3.566787] fec 5b040000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 02:bd:a6:91:7b:e1
[ 3.578507] libphy: fec_enet_mii_bus: probed
[ 3.583193] mdio_bus 5b040000.ethernet-1: MDIO device at address 1 is missing.
[ 3.590935] fec 5b040000.ethernet eth0: registered PHC device 0
[ 3.597489] iommu: Adding device 5b050000.ethernet to group 1
[ 3.604903] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.610748] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.616729] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.623698] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.629311] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.637153] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.643724] sky2: driver version 1.30
[ 3.651586] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.658130] ehci-pci: EHCI PCI platform driver
[ 3.662631] ehci-platform: EHCI generic platform driver
[ 3.668230] ehci-orion: EHCI orion driver
[ 3.672450] ehci-exynos: EHCI EXYNOS driver
[ 3.676793] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.683003] ohci-pci: OHCI PCI platform driver
[ 3.687497] ohci-platform: OHCI generic platform driver
[ 3.692955] ohci-exynos: OHCI EXYNOS driver
[ 3.698135] usbcore: registered new interface driver usb-storage
[ 3.704188] usbcore: registered new interface driver usb_ehset_test
[ 3.711911] usbmisc_imx 5b0d0200.usbmisc: 5b0d0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 3.721994] usbmisc_imx 5b0d0200.usbmisc: Linked as a consumer to regulator.0
[ 3.729454] usbmisc_imx 5b0e0200.usbmisc: 5b0e0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 3.739502] usbmisc_imx 5b0e0200.usbmisc: Linked as a consumer to regulator.0
[ 3.747685] imx_usb 5b0d0000.usb: 5b0d0000.usb supply vbus not found, using dummy regulator
[ 3.756085] imx_usb 5b0d0000.usb: Linked as a consumer to regulator.0
[ 3.780529] input: sc-powerkey as /devices/platform/sc-powerkey/input/input2
[ 3.788759] read mpl3115 chip id 0xc4
[ 3.792549] input: mpl3115 as /devices/virtual/input/input3
[ 3.798879] mpl3115 device driver probe successfully
[ 3.799102] isl29023 4-0044: 4-0044 supply vdd not found, using dummy regulator
[ 3.811472] isl29023 4-0044: Linked as a consumer to regulator.0
[ 3.811585] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.824275] input: isl29023 light sensor as /devices/virtual/input/input4
[ 3.831316] isl29023 4-0044: driver version 1.0 enabled
[ 3.838034] imx_sc_rtc rtc: rtc core: registered rtc as rtc0
[ 3.844187] i2c /dev entries driver
[ 3.857040] mxc-mipi-csi2 58227000.csi: mipi_csi2_probe
[ 3.882193] mxc-mipi-csi2 58247000.csi: mipi_csi2_probe
[ 3.917549] max9286_mipi 8-006a: max9286_read_reg:read reg error: reg=1e
[ 3.924263] max9286 is not found, chip id reg 0x1e = 0xffffffff.
[ 3.941533] max9286_mipi 9-006a: max9286_read_reg:read reg error: reg=1e
[ 3.948252] max9286 is not found, chip id reg 0x1e = 0xffffffff.
[ 3.954736] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 3.961129] mx8-img-md: Registered mxc_isi.1.capture as /dev/video1
[ 3.967514] mx8-img-md: Registered mxc_isi.2.capture as /dev/video2
[ 3.973897] mx8-img-md: Registered mxc_isi.3.capture as /dev/video3
[ 3.980279] mx8-img-md: Registered mxc_isi.4.capture as /dev/video4
[ 3.986662] mx8-img-md: Registered mxc_isi.5.capture as /dev/video5
[ 3.993048] mx8-img-md: Registered mxc_isi.6.capture as /dev/video6
[ 3.999438] mx8-img-md: Registered mxc_isi.7.capture as /dev/video7
[ 4.005830] mxc-isi 58170000.isi: register m2m device success
[ 4.011810] mxc-isi 58100000.isi: mxc_md_unregister_all unregister ISI channel[0]
[ 4.019379] mxc-isi 58110000.isi: mxc_md_unregister_all unregister ISI channel[1]
[ 4.026951] mxc-isi 58120000.isi: mxc_md_unregister_all unregister ISI channel[2]
[ 4.034521] mxc-isi 58130000.isi: mxc_md_unregister_all unregister ISI channel[3]
[ 4.042091] mxc-isi 58140000.isi: mxc_md_unregister_all unregister ISI channel[4]
[ 4.049658] mxc-isi 58150000.isi: mxc_md_unregister_all unregister ISI channel[5]
[ 4.057226] mxc-isi 58160000.isi: mxc_md_unregister_all unregister ISI channel[6]
[ 4.064788] mxc-isi 58170000.isi: mxc_md_unregister_all unregister ISI channel[7]
[ 4.073158] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video0 (81,0)
[ 4.081704] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video1 (81,1)
[ 4.096342] Bluetooth: HCI UART driver ver 2.3
[ 4.100807] Bluetooth: HCI UART protocol H4 registered
[ 4.105957] Bluetooth: HCI UART protocol BCSP registered
[ 4.111274] Bluetooth: HCI UART protocol ATH3K registered
[ 4.116703] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.123100] Bluetooth: HCI UART protocol Broadcom registered
[ 4.128797] Bluetooth: HCI UART protocol QCA registered
[ 4.135181] sdhci: Secure Digital Host Controller Interface driver
[ 4.141391] sdhci: Copyright(c) Pierre Ossman
[ 4.146108] Synopsys Designware Multimedia Card Interface Driver
[ 4.153951] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.161297] iommu: Adding device 5b010000.usdhc to group 2
[ 4.167257] mmc0: CQHCI version 5.10
[ 4.204536] mmc0: SDHCI controller on 5b010000.usdhc [5b010000.usdhc] using ADMA
[ 4.213875] iommu: Adding device 5b020000.usdhc to group 2
[ 4.219683] mmc1: CQHCI version 5.10
[ 4.223360] sdhci-esdhc-imx 5b020000.usdhc: Got CD GPIO
[ 4.228605] sdhci-esdhc-imx 5b020000.usdhc: Got WP GPIO
[ 4.233934] sdhci-esdhc-imx 5b020000.usdhc: Linked as a consumer to regulator.2
[ 4.274758] mmc1: SDHCI controller on 5b020000.usdhc [5b020000.usdhc] using ADMA
[ 4.287770] mxc_mlb150 5b060000.mlb: 5b060000.mlb supply reg_nvcc not found, using dummy regulator
[ 4.296805] mxc_mlb150 5b060000.mlb: Linked as a consumer to regulator.0
[ 4.303539] mxc_mlb150 5b060000.mlb: enalbe regulator
[ 4.308079] mmc0: new HS400 MMC card at address 0001
[ 4.308619] mxc_mlb150 5b060000.mlb: no iram assigned, using external mem
[ 4.314719] mmcblk0: mmc0:0001 R1J57L 29.1 GiB
[ 4.321292] mxc_emvsim 5a0d0000.sim0: emvsim register success
[ 4.325390] mmcblk0boot0: mmc0:0001 R1J57L partition 1 8.00 MiB
[ 4.337189] mmcblk0boot1: mmc0:0001 R1J57L partition 2 8.00 MiB
[ 4.343224] mmcblk0rpmb: mmc0:0001 R1J57L partition 3 4.00 MiB, chardev (236:0)
[ 4.350626] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.356906] Alternate GPT is invalid, using primary GPT.
[ 4.360766] caam 31400000.caam: ERA source: device tree.
[ 4.362290] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.384365] caam algorithms registered in /proc/crypto
[ 4.392272] caam_jr 31430000.jr2: registering rng-caam
[ 4.397741] caam 31400000.caam: caam pkc algorithms registered in /proc/crypto
[ 4.407238] platform caam_sm: blkkey_ex: 8 keystore units available
[ 4.413760] caam 31400000.caam: SM test passed
[ 4.419197] usbcore: registered new interface driver usbhid
[ 4.424782] usbhid: USB HID core driver
[ 4.430453] imx8qxp_adc 5a880000.adc: Linked as a consumer to regulator.4
[ 4.440392] optee: probing for conduit method from DT.
[ 4.445570] optee: revision 3.2 (6a22e6e8)
[ 4.445812] optee: initialized driver
[ 4.461129] ***** imx8qm_acm_init *****
[ 4.486744] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 4.493744] imx-cs42888: probe of sound-cs42888 failed with error -22
[ 4.500985] imx-wm8960 sound: wm8960-hifi <-> 59050000.sai mapping ok
[ 4.507470] imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
[ 4.514535] imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> direct -> CPU-Playback
[ 4.523247] imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
[ 4.530048] imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
[ 4.538589] imx-wm8960 sound: ASoC: no DMI vendor name!
[ 4.557900] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 4.565351] mmcblk1: mmc1:59b4 USDU1 14.7 GiB
[ 4.575261] mmcblk1: p1 p2
[ 4.658062] fsl-audmix 59840000.audmix: DAI FE name:HiFi-AUDMIX-FE-ai@59820000
[ 4.665340] fsl-audmix 59840000.audmix: DAI FE name:HiFi-AUDMIX-FE-ai@59830000
[ 4.672638] imx-audmix imx-audmix.0: DMA mask not set
[ 4.678033] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> 59820000.sai mapping ok
[ 4.685679] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> 59830000.sai mapping ok
[ 4.693302] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> audmix-0 mapping ok
[ 4.700577] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> audmix-1 mapping ok
[ 4.707827] imx-audmix imx-audmix.0: ASoC: no DMI vendor name!
[ 4.714786] NET: Registered protocol family 26
[ 4.719810] NET: Registered protocol family 10
[ 4.724854] Segment Routing with IPv6
[ 4.728568] NET: Registered protocol family 17
[ 4.733027] can: controller area network core (rev 20170425 abi 9)
[ 4.739320] NET: Registered protocol family 29
[ 4.743776] can: raw protocol (rev 20170425)
[ 4.748052] can: broadcast manager protocol (rev 20170425 t)
[ 4.753731] can: netlink gateway (rev 20170425) max_hops=1
[ 4.759381] Bluetooth: RFCOMM TTY layer initialized
[ 4.764279] Bluetooth: RFCOMM socket layer initialized
[ 4.769434] Bluetooth: RFCOMM ver 1.11
[ 4.773215] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.778537] Bluetooth: BNEP filters: protocol multicast
[ 4.783779] Bluetooth: BNEP socket layer initialized
[ 4.788753] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.794678] Bluetooth: HIDP socket layer initialized
[ 4.799701] lib80211: common routines for IEEE802.11 drivers
[ 4.805407] 9pnet: Installing 9P2000 support
[ 4.809744] Key type dns_resolver registered
[ 4.814617] registered taskstats version 1
[ 4.818727] Loading compiled-in X.509 certificates
[ 4.850660] imx8_cpufreq_init: cluster 0 running at freq 1200 MHz, suspend freq 1200 MHz
[ 4.859235] imx8_cpufreq_init: cluster 1 running at freq 1596 MHz, suspend freq 1596 MHz
[ 4.888669] imx_sc_rtc rtc: setting system clock to 1970-01-01 00:56:14 UTC (3374)
[ 4.896648] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.905763] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.912589] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
[ 4.920619] vref_1v8: disabling
[ 4.923801] ALSA device list:
[ 4.926780] #0: wm8960-audio
[ 4.929843] #1: imx-audmix
[ 4.995979] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.004344] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 5.013653] devtmpfs: mounted
[ 5.017288] Freeing unused kernel memory: 1472K
[ 5.022093] Run /sbin/init as init process
[ 5.168651] systemd[1]: System time before build time, advancing clock.
[ 5.183592] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 5.205538] systemd[1]: Detected architecture arm64.Welcome to NXP i.MX Release Distro 4.19-warrior (warrior)!
[ 5.234939] systemd[1]: Set hostname to <imx8qmmek>.
[ 5.364816] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.381896] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.552005] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.560961] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.577856] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.585791] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.601710] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.608399] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.626268] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.645778] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
Mounting Huge Pages File System...
Starting Load Kernel Modules...
Starting Setup Virtual Console...
[ OK ] Listening on Syslog Socket.
[ 5.724643] galcore: loading out-of-tree module taints kernel.
[ OK ] Listening on udev Control Socket.
Mounting POSIX Message Queue File System...
[ OK ] Listening on udev Kernel Socket.
[ 5.764669] Galcore version 6.4.0.228766
Starting udev Coldplug all Devices...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Created slice system-getty.slice.
Mounting Kernel Debug File System...
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on initctl Compatibility Named Pipe.
Starting Remount Root and Kernel File Systems...
[ OK ] Reached target Swap.
[ 5.906672] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
Mounting Temporary Directory (/tmp)...
[ OK ] Listening on Journal Audit Socket.
Starting Journal Service...
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target Paths.
Starting Create list of required st…ce nodes for the current kernel...
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Setup Virtual Console.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
Starting Create Static Device Nodes in /dev...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Containers.
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Mounted /var/volatile.
[ 6.382368] systemd-journald[3244]: Received request to flush runtime journal from PID 1
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
Starting Start Psplash Boot Screen...
Starting Create Volatile Files and Directories...
[ OK ] Started Start Psplash Boot Screen.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Service...
Starting Network Time Synchronization...
[ 6.583209] [VPU Encoder] enable mu for core[0]
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 6.595337] [VPU Encoder] vpu encoder core[0] firmware version is 1.2.4
[ OK ] Started Network Service.
[ OK ] Found device /dev/ttyLP0.
[ 6.684515] cfg80211: failed to load regulatory.db
[ 6.724188] fsl-audmix 59840000.audmix: Started TDM1 needed for config propagation!
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…s of backlight:lvds_backlight@1...
Starting Load/Save Screen Backlight…s of backlight:lvds_backlight@0...
[ OK ] Started Network Time Synchronization.
[ OK ] Started Load/Save Screen Backlight …ess of backlight:lvds_backlight@1.
[ OK ] Started Load/Save Screen Backlight …ess of backlight:lvds_backlight@0.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
Starting Console System Startup Logging...
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started TEE Supplicant.
Starting System Logging Service...
Starting Login Service...
[ OK ] Started Configuration for i.MX GPU (Former rc_gpu.S).
Starting Save/Restore Sound Card State...
[ OK [ 7.208692] fsl-audmix 59840000.audmix: Started TDM1 needed for config propagation!
] Started Periodic Command Scheduler.
[ OK ] Started Job spooling tools.
Starting Network Time Service (one-shot ntpdate mode)...
[ OK ] Started D-Bus System Message Bus.
Starting Connection service...
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
Starting RPC Bind Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting Telephony service...
[ OK ] Started Console System Startup Logging.
[ OK ] Started System Logging Service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Network Time Service (one-shot ntpdate mode).
[ OK ] Started RPC Bind Service.
[ 7.590111] Atheros 8031 ethernet 5b040000.ethernet-1:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=5b040000.ethernet-1:00, irq=POLL)
[ 7.604207] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.061704] switch cluster 0 cpu-freq governor to schedutil
[ 8.081571] switch cluster 1 cpu-freq governor to schedutil
Starting Hostname Service...
Starting WPA supplicant...
[ OK ] Created slice system-systemd\x2dfsck.slice.
Starting File System Check on /dev/mmcblk0p5...
Starting File System Check on /dev/mmcblk1p1...
Starting File System Check on /dev/mmcblk0p6...
Starting File System Check on /dev/mmcblk0p10...
Starting File System Check on /dev/mmcblk0p12...
Starting File System Check on /dev/mmcblk0p11...
[ OK ] Reached target Sound Card.
Starting Kernel Logging Service...
[ OK ] Started Updates psplash to basic.
[ OK ] Started WPA supplicant.
[ OK ] Started Telephony service.
[ OK ] Started Connection service.
[ OK ] Started Login Service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Reached target Network.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting /etc/rc.local Compatibility...
Starting Permit User Sessions...
[ OK ] Started Update psplash to network.
Starting Terminate Psplash Boot Screen...
[ OK ] Started Permit User Sessions.
[ OK ] Started /etc/rc.local Compatibility.
[FAILED] Failed to start Terminate Psplash Boot Screen.
See 'systemctl status psplash-quit.service' for details.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyLP0.
Starting Weston Wayland Compositor (on tty7)...
[ OK ] Started File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ OK ] Started Weston Wayland Compositor (on tty7).
[ OK ] Started Hostname Service.
[ OK ] Mounted /run/media/mmcblk1p1.
[ OK ] Created slice User Slice of UID 0.
[ OK ] Created slice system-user\x2druntime\x2ddir.slice.
[ OK ] Started /run/user/0 mount wrapper.
Starting User Man[ 8.687459] audit: type=1006 audit(1572034392.516:2): pid=4415 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
ager for UID 0...
[FAILED] Failed to start File System Check on /dev/mmcblk0p6.
See 'systemctl status systemd-fsck@dev-mmcblk0p6.service' for details.
[DEPEND] Dependency failed for /run/media/mmcblk0p6.
[ OK ] Started Session c1 of user root.
[ OK ] Started File System Check on /dev/mmcblk0p12.
Mounting /run/media/mmcblk0p12...
[FAILED] Failed to start File System Check on /dev/mmcblk0p11.
See 'systemctl status systemd-fsck@dev-mmcblk0p11.service' for details.
[ 8.786955] EXT4-fs warning (device mmcblk0p12): ext4_enable_quotas:5749: Failed to enable quota tracking (type=0, err=-3). Please run e2fsck to fix.
[ 8.800837] EXT4-fs (mmcblk0p12): mount failed
[DEPEND] Dependency failed for /run/media/mmcblk0p11.
[FAILED] Failed to start File System Check on /dev/mmcblk0p10.
See 'systemctl status systemd-fsck@dev-mmcblk0p10.service' for details.
[DEPEND] Dependency failed for /run/media/mmcblk0p10.
[FAILED] Failed to mount /run/media/mmcblk0p12.
See 'systemctl status run-media-mmcblk0p12.mount' for details.
[FAILED] Failed to start File System Check on /dev/mmcblk0p5.
See 'systemctl status systemd-fsck@dev-mmcblk0p5.service' for details.
[DEPEND] Dependency failed for /run/media/mmcblk0p5.
[ OK ] Started Kernel Logging Service.
[ OK ] Started User Manager for UID 0.
Stopping User Manager for UID 0...
[ OK ] Stopped User Manager for UID 0.
[ OK ] Removed slice User Slice of UID 0.
Stopping /run/user/0 mount wrapper...
[ OK ] Stopped /run/user/0 mount wrapper.NXP i.MX Release Distro 4.19-warrior imx8qmmek ttyLP0
imx8qmmek login:
Hi, @mop
I have tested your case on my site, use i.MX8QM mek board, withe BSP version is LF_v6.1.22-2.0.0, dtb file is imx8qm-mek.dtb. And there is no problem on LVDS-HDMI. Please use the same with me and check if is your HW connection error.
B.R
Hi @pengyong_zhang,
One more question is, is there a schematic for MCIMX8QM-CPU REV B black board?
I had only found REV C.
Hi @pengyong_zhang,
It is the same. After those version testings, I have suspected the hardware failures. I have checked the shorts and the 1.8/3.3 VDD seems fine, but there is a crack on the U32 (NTS0104PW, red circle).
Like this pose:
https://community.nxp.com/t5/i-MX-Processors/How-to-display-with-LVDS-to-HDMI-adapter-card-on-MCIMX8...
I have no white smoke, but this kit is given by others, I am not sure about their operations.
I have ordered this voltage converter chip, but why is this chip so easy to damage? Do I wonder if this chip is reliable?
Any reply will be appreciated.
It is the same, red and yellow LED light, but there are no signals detected by the monitor.
Here are U-boot settings and the boot log (4.19.35):
Normal Boot
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 29C
Board: iMX8QM MEK
Boot: SD1
DRAM: 5.8 GiB
OK
In: serial
Out: serial
Net:
Warning: ethernet@5b040000 (eth0) using random MAC address - 96:75:65:b6:f6:7d
Warning: ethernet@5b050000 (eth1) using random MAC address - 22:22:b5:60:a7:1e
Fastboot: Normal
Normal Boot
=> printenv
auth_os=auth_cntr ${cntr_addr}
baudrate=115200
board_name=MEK
board_rev=iMX8QM
boot_fdt=try
boot_os=booti ${loadaddr} - ${fdt_addr};
bootargs=console=ttyLP0,115200 earlycon root=/dev/mmcblk1p2 rootwait rw video=HDMI-A-1:1280x720@60
bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if test ${sec_boot} = yes; then if run loadcntr; then run mmcboot; else run netboot; fi; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi
bootcmd_mfg=run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee} = yes; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else booti ${loadaddr} ${initrd_addr} ${fdt_addr}; fi; else echo "Run fastboot ..."; fastboot auto; fi;
bootdelay=3
bootscript=echo Running bootscript from mmc ...; source
cntr_addr=0x98000000
cntr_file=os_cntr_signed.bin
commit_atf=70fa7bc
commit_mkimage=1c2277b9
commit_scfw=550f3079
commit_secofw=d7523fe8
console=ttyLP0
dom0fdt_file=fsl-imx8qm-mek-dom0.dtb
domu-android-auto=no
emmc_dev=0
ethact=ethernet@5b040000
ethprime=eth0
fastboot_dev=mmc1
fdt_addr=0x83000000
fdt_file=fsl-imx8qm-mek-hdmi.dtb
fdt_high=0xffffffffffffffff
fdtcontroladdr=8565dd80
hdp_addr=0x9c000000
hdp_file=hdmitxfw.bin
hdprx_addr=0x9c800000
hdprx_file=hdmirxfw.bin
image=Image
initrd_addr=0x83100000
initrd_high=0xffffffffffffffff
jh_mmcboot=setenv fdt_file fsl-imx8qm-mek-root.dtb;setenv boot_os 'scu_rm dtb ${fdt_addr}; booti ${loadaddr} - ${fdt_addr};'; run mmcboot;
jh_netboot=setenv fdt_file fsl-imx8qm-mek-root.dtb;setenv boot_os 'scu_rm dtb ${fdt_addr}; booti ${loadaddr} - ${fdt_addr};'; run netboot;
kboot=booti
loadaddr=0x80280000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file}
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loadhdp=fatload mmc ${mmcdev}:${mmcpart} ${hdp_addr} ${hdp_file}
loadhdprx=fatload mmc ${mmcdev}:${mmcpart} ${hdprx_addr} ${hdprx_file}
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_0_image}
loadm4image_1=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_1_image}
m4_0_image=m4_0.bin
m4_1_image=m4_1.bin
m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0
m4boot_1=run loadm4image_1; dcache flush; bootaux ${loadaddr} 1
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc clk_ignore_unused
mmcargs=setenv bootargs console=${console},${baudrate} earlycon root=${mmcroot} video=HDMI-A-1:1280x720@60
mmcautodetect=yes
mmcboot=echo Booting from mmc ...; if run loadhdp; then; hdp load ${hdp_addr}; fi;if run loadhdprx; then; hdprx load ${hdprx_addr}; fi;run mmcargs; if test ${sec_boot} = yes; then if run auth_os; then run boot_os; else echo ERR: failed to authenticate; fi; else if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then run boot_os; else echo WARN: Cannot load the DT; fi; else echo wait for boot; fi;fi;
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk1p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} earlycon root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if ${get_cmd} ${hdp_addr} ${hdp_file}; then; hdp load ${hdp_addr}; fi;if ${get_cmd} ${hdprx_addr} ${hdprx_file}; then; hdprx load ${hdprx_addr}; fi;if test ${sec_boot} = yes; then ${get_cmd} ${cntr_addr} ${cntr_file}; if run auth_os; then run boot_os; else echo ERR: failed to authenticate; fi; else ${get_cmd} ${loadaddr} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then run boot_os; else echo WARN: Cannot load the DT; fi; else booti; fi;fi;
panel=NULL
script=boot.scr
sd_dev=1
sec_boot=no
serial#=0913380e82964f91
soc_type=imx8qm
xenboot_common=${get_cmd} ${loadaddr} xen;${get_cmd} ${fdt_addr} ${dom0fdt_file};if ${get_cmd} ${hdp_addr} ${hdp_file}; then; hdp load ${hdp_addr}; fi;if ${get_cmd} ${hdprx_addr} ${hdprx_file}; then; hdprx load ${hdprx_addr}; fi;${get_cmd} ${xenlinux_addr} ${image};fdt addr ${fdt_addr};fdt resize 256;fdt set /chosen/module@0 reg <0x00000000 ${xenlinux_addr} 0x00000000 0x${filesize}>; fdt set /chosen/module@0 bootargs "${bootargs} ${xenlinux_bootargs}"; if test ${domu-android-auto} = yes; then; fdt set /domu/doma android-auto <1>;fdt rm /gpio@5d090000 power-domains;fi;setenv bootargs ${xenhyper_bootargs};booti ${loadaddr} - ${fdt_addr};
xenhyper_bootargs=console=dtuart dtuart=/serial@5a060000 dom0_mem=2048M dom0_max_vcpus=2 dom0_vcpus_pin=true hmp-unsafe=true
xenlinux_addr=0x9e000000
xenlinux_bootargs=
xenlinux_console=hvc0 earlycon=xen
xenmmcboot=setenv get_cmd "fatload mmc ${mmcdev}:${mmcpart}";setenv console ${xenlinux_console};run mmcargs;run xenboot_common;
xennetboot=setenv get_cmd dhcp;setenv console ${xenlinux_console};run netargs;run xenboot_common;Environment size: 5028/8188 bytes
=> boot
24263168 bytes read in 312 ms (74.2 MiB/s)
99011 bytes read in 8 ms (11.8 MiB/s)
Using Device Tree in place at 0000000083000000, end 000000008301b2c2
/dma-controller@5a1f0000, 66932
/dma-controller@591F0000, 67776
/dma-controller@599F0000, 68820Starting kernel ...
[ 0.000000] NUMA: NODE_DATA [mem 0x97ff70040-0x97ff71aff]
[ 0.000003] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.011334] Console: colour dummy device 80x25
[ 0.015504] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.025686] pid_max: default: 32768 minimum: 301
[ 0.030351] Security Framework initialized
[ 0.037002] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.045266] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.052124] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058960] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.090293] ASID allocator initialised with 32768 entries
[ 0.103376] rcu: Hierarchical SRCU implementation.
[ 0.117842] *****Initialized MU
[ 0.120660] ***** imx8_init_pm_domains *****
[ 0.126474] CPU identified as i.MX8QM, silicon rev 1.1
[ 0.133360] EFI services will not be available.
[ 0.145573] smp: Bringing up secondary CPUs ...
[ 0.183175] Detected VIPT I-cache on CPU1
[ 0.183205] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.183235] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.215185] Detected VIPT I-cache on CPU2
[ 0.215200] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.215215] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.247237] Detected VIPT I-cache on CPU3
[ 0.247251] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.247266] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.280988] CPU features: enabling workaround for EL2 vector hardening
[ 0.280995] Detected PIPT I-cache on CPU4
[ 0.281012] GICv3: CPU4: found redistributor 100 region 0:0x0000000051b80000
[ 0.281029] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.311332] Detected PIPT I-cache on CPU5
[ 0.311343] GICv3: CPU5: found redistributor 101 region 0:0x0000000051ba0000
[ 0.311355] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.311415] smp: Brought up 1 node, 6 CPUs
[ 0.408914] SMP: Total of 6 processors activated.
[ 0.413603] CPU features: detected: GIC system register CPU interface
[ 0.420040] CPU features: detected: 32-bit EL0 Support
[ 0.431403] CPU: All CPU(s) started at EL2
[ 0.435182] alternatives: patching kernel code
[ 0.440507] devtmpfs: initialized
[ 0.457253] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.466705] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.493581] pinctrl core: initialized pinctrl subsystem
[ 0.500674] DMI not present or invalid.
[ 0.504568] NET: Registered protocol family 16
[ 0.509135] audit: initializing netlink subsys (disabled)
[ 0.514278] audit: type=2000 audit(0.408:1): state=initialized audit_enabled=0 res=1
[ 0.521944] cpuidle: using governor menu
[ 0.526189] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.533251] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.545190] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.553304] Serial: AMBA PL011 UART driver
[ 0.557234] imx rpmsg driver is registered.
[ 0.564120] MU and Power domains initialized
[ 0.568055] ***** imx8qm_clocks_init *****
[ 0.576037] random: fast init done
[ 0.658079] imx8qm-pinctrl iomuxc: Invalid fsl,pins or pins property in node /iomuxc/imx8qm-mek/wifi_initgrp
[ 0.667582] imx8qm-pinctrl iomuxc: initialized IMX pinctrl driver
[ 0.705950] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.714810] mxs_phy 5b100000.usbphy: Linked as a consumer to regulator.0
[ 0.741642] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.748376] cryptd: max_cpu_qlen set to 1000
[ 0.761357] ACPI: Interpreter disabled.
[ 0.781799] vgaarb: loaded
[ 0.784426] SCSI subsystem initialized
[ 0.788304] usbcore: registered new interface driver usbfs
[ 0.793507] usbcore: registered new interface driver hub
[ 0.798814] usbcore: registered new device driver usb
[ 0.804110] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.812435] usb_phy_generic usbphynop1: Linked as a consumer to regulator.0
[ 0.819446] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.836701] i2c i2c-2: LPI2C adapter registered
[ 0.842050] i2c i2c-3: LPI2C adapter registered
[ 0.847432] max732x 4-0068: failed reading
[ 0.851200] max732x: probe of 4-0068 failed with error -5
[ 0.857006] i2c i2c-4: LPI2C adapter registered
[ 0.862073] i2c i2c-5: LPI2C adapter registered
[ 0.867152] i2c i2c-6: LPI2C adapter registered
[ 0.872261] i2c i2c-7: LPI2C adapter registered
[ 0.877115] i2c i2c-8: LPI2C adapter registered
[ 0.883206] media: Linux media interface: v0.10
[ 0.887489] videodev: Linux video capture interface: v2.00
[ 0.893210] pps_core: LinuxPPS API ver. 1 registered
[ 0.897833] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.906974] PTP clock support registered
[ 0.912355] Advanced Linux Sound Architecture Driver Initialized.
[ 0.918679] Bluetooth: Core ver 2.22
[ 0.921933] NET: Registered protocol family 31
[ 0.926347] Bluetooth: HCI device and connection manager initialized
[ 0.932695] Bluetooth: HCI socket layer initialized
[ 0.937554] Bluetooth: L2CAP socket layer initialized
[ 0.942609] Bluetooth: SCO socket layer initialized
[ 0.947828] clocksource: Switched to clocksource arch_sys_counter
[ 0.953748] VFS: Disk quotas dquot_6.6.0
[ 0.957538] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.964475] pnp: PnP ACPI: disabled
[ 0.973711] NET: Registered protocol family 2
[ 0.978373] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.985999] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.993624] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.000802] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.007123] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.013225] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.019854] NET: Registered protocol family 1
[ 1.024370] RPC: Registered named UNIX socket transport module.
[ 1.029955] RPC: Registered udp transport module.
[ 1.034643] RPC: Registered tcp transport module.
[ 1.039334] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.047003] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.055168] kvm [1]: 8-bit VMID
[ 1.058532] kvm [1]: vgic-v2@52020000
[ 1.061873] kvm [1]: GIC system register CPU interface enabled
[ 1.067771] kvm [1]: vgic interrupt IRQ1
[ 1.071707] kvm [1]: Hyp mode initialized successfully
[ 1.079546] Initialise system trusted keyrings
[ 1.083741] workingset: timestamp_bits=44 max_order=21 bucket_order=0
[ 1.095797] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.101906] NFS: Registering the id_resolver key type
[ 1.106644] Key type id_resolver registered
[ 1.110788] Key type id_legacy registered
[ 1.114792] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.121493] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.128152] 9p: Installing v9fs 9p2000 file system support
[ 1.133378] pstore: using deflate compression
[ 1.143194] Key type asymmetric registered
[ 1.146948] Asymmetric key parser 'x509' registered
[ 1.151851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.159197] io scheduler noop registered
[ 1.163193] io scheduler cfq registered (default)
[ 1.167797] io scheduler mq-deadline registered
[ 1.172319] io scheduler kyber registered
[ 1.197911] imx6q-pcie 5f000000.pcie: Linked as a consumer to regulator.1
[ 1.204430] imx6q-pcie 5f000000.pcie: No cache used with register defaults set!
[ 1.211737] imx6q-pcie 5f000000.pcie: host bridge /hsio/pcie@5f000000 ranges:
[ 1.218789] imx6q-pcie 5f000000.pcie: No bus range found for /hsio/pcie@5f000000, using [bus 00-ff]
[ 1.228007] imx6q-pcie 5f000000.pcie: IO 0x6ff80000..0x6ff8ffff -> 0x00000000
[ 1.235386] imx6q-pcie 5f000000.pcie: MEM 0x60000000..0x6fefffff -> 0x60000000
[ 1.489672] imx6q-pcie 5f000000.pcie: phy link never came up
[ 1.495002] imx6q-pcie 5f000000.pcie: failed to initialize host
[ 1.500900] imx6q-pcie 5f000000.pcie: unable to add pcie port.
[ 1.506860] imx6q-pcie 5f000000.pcie: Dropping the link to regulator.1
[ 1.513299] imx6q-pcie: probe of 5f000000.pcie failed with error -110
[ 1.520714] pwm-backlight lvds_backlight@0: lvds_backlight@0 supply power not found, using dummy regulator
[ 1.530096] pwm-backlight lvds_backlight@0: Linked as a consumer to regulator.0
[ 1.538631] pwm-backlight lvds_backlight@1: lvds_backlight@1 supply power not found, using dummy regulator
[ 1.547978] pwm-backlight lvds_backlight@1: Linked as a consumer to regulator.0
[ 1.566490] Bus freq driver module loaded
[ 1.570651] seco_mu 31560000.mu: current SECO FW do not support SHE
[ 1.576620] seco_mu: probe of 31560000.mu failed with error -524
[ 1.582665] seco_mu 31570000.mu: current SECO FW do not support SHE
[ 1.588850] seco_mu: probe of 31570000.mu failed with error -524
[ 1.594904] seco_mu 31580000.mu: current SECO FW do not support SHE
[ 1.601097] seco_mu: probe of 31580000.mu failed with error -524
[ 1.616629] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.625794] SuperH (H)SCI(F) driver initialized
[ 1.631310] msm_serial: driver initialized
[ 1.635930] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 70, base_baud = 5000000) is a FSL_LPUAR[ 1.647095] console [ttyLP0] enabled
[ 1.654076] bootconsole [lpuart32] disabled
[ 1.662651] fsl-lpuart 5a060000.serial: NO DMA tx channel, run at cpu mode
[ 1.669543] fsl-lpuart 5a060000.serial: NO DMA rx channel, run at cpu mode
[ 1.676909] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 71, base_baud = 5000000) is a FSL_LPUART
[ 1.686760] imx8qm-pinctrl iomuxc: pin_config_set op failed for pin 13
[ 1.693303] fsl-lpuart 5a090000.serial: Error applying setting, reverse things back
[ 1.701252] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 72, base_baud = 5000000) is a FSL_LPUART
[ 1.713711] arm-smmu 51400000.iommu: probing hardware configuration...
[ 1.720251] arm-smmu 51400000.iommu: SMMUv2 with:
[ 1.724968] arm-smmu 51400000.iommu: stage 1 translation
[ 1.730379] arm-smmu 51400000.iommu: stage 2 translation
[ 1.735791] arm-smmu 51400000.iommu: nested translation
[ 1.741110] arm-smmu 51400000.iommu: stream matching with 32 register groups
[ 1.748262] arm-smmu 51400000.iommu: 32 context banks (0 stage-2 only)
[ 1.754891] arm-smmu 51400000.iommu: Supported page sizes: 0x61311000
[ 1.761429] arm-smmu 51400000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 1.767969] arm-smmu 51400000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 1.818368] imx8-dpr-channel 560d0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.826519] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56050000.prg
[ 1.834542] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.842679] imx8-dpr-channel 560f0000.dpr-channel: Linked as a consumer to 56060000.prg
[ 1.852837] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56070000.prg
[ 1.860866] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56080000.prg
[ 1.870984] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 56090000.prg
[ 1.879002] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 560a0000.prg
[ 1.889116] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560b0000.prg
[ 1.897141] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560c0000.prg
[ 1.907326] imx8-dpr-channel 570d0000.dpr-channel: Linked as a consumer to 57040000.prg
[ 1.915465] imx8-dpr-channel 570e0000.dpr-channel: Linked as a consumer to 57050000.prg
[ 1.923489] imx8-dpr-channel 570e0000.dpr-channel: Linked as a consumer to 57040000.prg
[ 1.931645] imx8-dpr-channel 570f0000.dpr-channel: Linked as a consumer to 57060000.prg
[ 1.941800] imx8-dpr-channel 57100000.dpr-channel: Linked as a consumer to 57070000.prg
[ 1.949824] imx8-dpr-channel 57100000.dpr-channel: Linked as a consumer to 57080000.prg
[ 1.959939] imx8-dpr-channel 57110000.dpr-channel: Linked as a consumer to 57090000.prg
[ 1.967961] imx8-dpr-channel 57110000.dpr-channel: Linked as a consumer to 570a0000.prg
[ 1.978085] imx8-dpr-channel 57120000.dpr-channel: Linked as a consumer to 570b0000.prg
[ 1.986108] imx8-dpr-channel 57120000.dpr-channel: Linked as a consumer to 570c0000.prg
[ 1.997798] dpu-core 56180000.dpu: Linked as a consumer to 56100000.dpr-channel
[ 2.005130] dpu-core 56180000.dpu: Linked as a consumer to 56110000.dpr-channel
[ 2.012460] dpu-core 56180000.dpu: Linked as a consumer to 560f0000.dpr-channel
[ 2.019785] dpu-core 56180000.dpu: Linked as a consumer to 56120000.dpr-channel
[ 2.027115] dpu-core 56180000.dpu: Linked as a consumer to 56020000.pixel-combiner
[ 2.035468] dpu-core 56180000.dpu: driver probed
[ 2.040861] dpu-core 57180000.dpu: Linked as a consumer to 57100000.dpr-channel
[ 2.048194] dpu-core 57180000.dpu: Linked as a consumer to 57110000.dpr-channel
[ 2.055519] dpu-core 57180000.dpu: Linked as a consumer to 570f0000.dpr-channel
[ 2.062847] dpu-core 57180000.dpu: Linked as a consumer to 57120000.dpr-channel
[ 2.070167] dpu-core 57180000.dpu: Linked as a consumer to 57020000.pixel-combiner
[ 2.078293] dpu-core 57180000.dpu: driver probed
[ 2.086913] adv7511 2-003d: 2-003d supply avdd not found, using dummy regulator
[ 2.094284] adv7511 2-003d: Linked as a consumer to regulator.0
[ 2.100221] adv7511 2-003d: 2-003d supply dvdd not found, using dummy regulator
[ 2.107587] adv7511 2-003d: 2-003d supply pvdd not found, using dummy regulator
[ 2.114936] adv7511 2-003d: 2-003d supply a2vdd not found, using dummy regulator
[ 2.122367] adv7511 2-003d: 2-003d supply v3p3 not found, using dummy regulator
[ 2.129720] adv7511 2-003d: 2-003d supply v1p2 not found, using dummy regulator
[ 2.137546] adv7511 2-003d: Probe failed. Remote port 'mipi_dsi_bridge@56228000' disabled
[ 2.145913] adv7511 3-003d: 3-003d supply avdd not found, using dummy regulator
[ 2.153343] adv7511 3-003d: Linked as a consumer to regulator.0
[ 2.159275] adv7511 3-003d: 3-003d supply dvdd not found, using dummy regulator
[ 2.166627] adv7511 3-003d: 3-003d supply pvdd not found, using dummy regulator
[ 2.173971] adv7511 3-003d: 3-003d supply a2vdd not found, using dummy regulator
[ 2.181414] adv7511 3-003d: 3-003d supply v3p3 not found, using dummy regulator
[ 2.188782] adv7511 3-003d: 3-003d supply v1p2 not found, using dummy regulator
[ 2.196513] adv7511 3-003d: Probe failed. Remote port 'mipi_dsi_bridge@57228000' disabled
[ 2.205549] it6263 6-004c: Probe failed. Remote port 'lvds-channel@0' disabled
[ 2.213289] imx-drm display-subsystem: parent device of /ldb@562410e0/lvds-channel@0 is not available
[ 2.226381] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.233018] [drm] No driver support for vblank timestamp query.
[ 2.239008] dpu-core 56180000.dpu: Linked as a consumer to 560d0000.dpr-channel
[ 2.246340] dpu-core 56180000.dpu: Linked as a consumer to 560e0000.dpr-channel
[ 2.253680] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.261824] dpu-core 57180000.dpu: Linked as a consumer to 570d0000.dpr-channel
[ 2.269150] dpu-core 57180000.dpu: Linked as a consumer to 570e0000.dpr-channel
[ 2.276473] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 2.285069] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.292707] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.300647] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 2.308300] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 2.315684] i.mx8-hdp 56268000.hdmi: invalid resource
[ 2.320747] i.mx8-hdp 56268000.hdmi: Failed to get HDP RESET base register
[ 2.327874] imx8qm_ipg_clock_set_rate, dig_pll was 675 MHz, changing to 800 MHz
[ 2.337236] CDN_API_SetClock completed
[ 2.340995] [drm] Started firmware!
[ 2.344492] [drm] CDN_API_CheckAlive returned ret = 0
[ 2.349594] [drm] CDN_API_MainControl_blocking ret = 0 sts = 1
[ 2.355521] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 2.364056] [drm] CDN_API_General_getCurVersion - ver 26098 verlib 20691
[ 2.370787] [drm] phy_cfg_hdp() num_lanes: 4, mode:3840x2160p60, color depth: 8-bit, encoding: 1
[ 2.379774] [drm] Pixel clock frequency (594000 kHz) is supported in this color depth (8-bit). Settings found in row 4
[ 2.390479] [drm] Character clock frequency: 594000 kHz.
[ 2.395804] [drm] VCO frequency (5940000 kHz) is supported. Settings found in row 36
[ 2.429355] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 2.436613] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 2.443683] [drm] hdmi-audio-codec driver bound to HDMI
[ 2.448930] imx-drm display-subsystem: bound 56268000.hdmi (ops imx_hdp_imx_ops)
[ 2.456437] nwl_dsi-imx mipi_dsi@56228000: No bridge found, skipping encoder creation
[ 2.464284] imx-drm display-subsystem: bound mipi_dsi@56228000 (ops imx_nwl_dsi_component_ops)
[ 2.472959] nwl_dsi-imx mipi_dsi@57228000: No bridge found, skipping encoder creation
[ 2.480798] imx-drm display-subsystem: bound mipi_dsi@57228000 (ops imx_nwl_dsi_component_ops)
[ 2.489520] [drm] Cannot find any crtc or sizes
[ 2.494588] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.509513] loop: module loaded
[ 2.513636] input: fxos8700 as /devices/platform/5a800000.i2c/i2c-4/4-001e/input/input0
[ 2.523623] fxos8700 device driver probe successfully
[ 2.524347] input: fxas2100x as /devices/platform/5a800000.i2c/i2c-4/4-0020/input/input1
[ 2.538180] fxas2100x 4-0020: fxas2100x device driver probe successfully
[ 2.547741] iommu: Adding device 5f020000.sata to group 0
[ 2.556587] ahci-imx 5f020000.sata: imx8qm sata only supports 32bit dma.
[ 2.563305] ahci-imx 5f020000.sata: ext_osc is not specified.
[ 2.569063] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 2.575902] ahci-imx 5f020000.sata: No cache used with register defaults set!
[ 2.583893] ahci-imx 5f020000.sata: external osc is used.
[ 2.592123] ahci-imx 5f020000.sata: no ahb clock.
[ 2.596896] ahci-imx 5f020000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 2.605791] ahci-imx 5f020000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sadm sds apst
[ 2.616568] scsi host0: ahci-imx
[ 2.620096] ata1: SATA max UDMA/133 mmio [mem 0x5f020000-0x5f02ffff] port 0x100 irq 148
[ 2.630698] slram: not enough parameters.
[ 2.639134] libphy: Fixed MDIO Bus: probed
[ 2.643556] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 2.649541] tun: Universal TUN/TAP device driver, 1.6
[ 2.654777] CAN device driver interface
[ 2.661701] iommu: Adding device 5b040000.ethernet to group 1
[ 2.668063] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, using dummy regulator
[ 2.676931] fec 5b040000.ethernet: Linked as a consumer to regulator.0
[ 2.683775] pps pps0: new PPS source ptp0
[ 2.688509] fec 5b040000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 2.698528] fec 5b040000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: da:5e:32:7e:16:10
[ 2.710197] libphy: fec_enet_mii_bus: probed
[ 2.714848] mdio_bus 5b040000.ethernet-1: MDIO device at address 1 is missing.
[ 2.722585] fec 5b040000.ethernet eth0: registered PHC device 0
[ 2.729128] iommu: Adding device 5b050000.ethernet to group 1
[ 2.736445] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.742288] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.748258] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.755232] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.760844] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.768684] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.775271] sky2: driver version 1.30
[ 2.783089] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.789637] ehci-pci: EHCI PCI platform driver
[ 2.794126] ehci-platform: EHCI generic platform driver
[ 2.799652] ehci-orion: EHCI orion driver
[ 2.803877] ehci-exynos: EHCI EXYNOS driver
[ 2.808226] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.814436] ohci-pci: OHCI PCI platform driver
[ 2.818919] ohci-platform: OHCI generic platform driver
[ 2.824387] ohci-exynos: OHCI EXYNOS driver
[ 2.829520] usbcore: registered new interface driver usb-storage
[ 2.835606] usbcore: registered new interface driver usb_ehset_test
[ 2.843331] usbmisc_imx 5b0d0200.usbmisc: 5b0d0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.853389] usbmisc_imx 5b0d0200.usbmisc: Linked as a consumer to regulator.0
[ 2.860696] usbmisc_imx 5b0e0200.usbmisc: 5b0e0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.870741] usbmisc_imx 5b0e0200.usbmisc: Linked as a consumer to regulator.0
[ 2.878804] imx_usb 5b0d0000.usb: 5b0d0000.usb supply vbus not found, using dummy regulator
[ 2.887191] imx_usb 5b0d0000.usb: Linked as a consumer to regulator.0
[ 2.911572] input: sc-powerkey as /devices/platform/sc-powerkey/input/input2
[ 2.919779] read mpl3115 chip id 0xc4
[ 2.923580] input: mpl3115 as /devices/virtual/input/input3
[ 2.929901] mpl3115 device driver probe successfully
[ 2.930114] isl29023 4-0044: 4-0044 supply vdd not found, using dummy regulator
[ 2.942088] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.942452] isl29023 4-0044: Linked as a consumer to regulator.0
[ 2.960603] input: isl29023 light sensor as /devices/virtual/input/input4
[ 2.967639] isl29023 4-0044: driver version 1.0 enabled
[ 2.974331] imx_sc_rtc rtc: rtc core: registered rtc as rtc0
[ 2.980490] i2c /dev entries driver
[ 2.992930] mxc-mipi-csi2 58227000.csi: mipi_csi2_probe
[ 3.016608] mxc-mipi-csi2 58247000.csi: mipi_csi2_probe
[ 3.051999] max9286_mipi 7-006a: max9286_read_reg:read reg error: reg=1e
[ 3.058717] max9286 is not found, chip id reg 0x1e = 0xffffffff.
[ 3.075978] max9286_mipi 8-006a: max9286_read_reg:read reg error: reg=1e
[ 3.082696] max9286 is not found, chip id reg 0x1e = 0xffffffff.
[ 3.089143] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 3.095530] mx8-img-md: Registered mxc_isi.1.capture as /dev/video1
[ 3.101910] mx8-img-md: Registered mxc_isi.2.capture as /dev/video2
[ 3.108296] mx8-img-md: Registered mxc_isi.3.capture as /dev/video3
[ 3.114684] mx8-img-md: Registered mxc_isi.4.capture as /dev/video4
[ 3.121086] mx8-img-md: Registered mxc_isi.5.capture as /dev/video5
[ 3.127474] mx8-img-md: Registered mxc_isi.6.capture as /dev/video6
[ 3.133853] mx8-img-md: Registered mxc_isi.7.capture as /dev/video7
[ 3.140225] mxc-isi 58170000.isi: register m2m device success
[ 3.146196] mxc-isi 58100000.isi: mxc_md_unregister_all unregister ISI channel[0]
[ 3.153761] mxc-isi 58110000.isi: mxc_md_unregister_all unregister ISI channel[1]
[ 3.161326] mxc-isi 58120000.isi: mxc_md_unregister_all unregister ISI channel[2]
[ 3.168896] mxc-isi 58130000.isi: mxc_md_unregister_all unregister ISI channel[3]
[ 3.176462] mxc-isi 58140000.isi: mxc_md_unregister_all unregister ISI channel[4]
[ 3.184025] mxc-isi 58150000.isi: mxc_md_unregister_all unregister ISI channel[5]
[ 3.191593] mxc-isi 58160000.isi: mxc_md_unregister_all unregister ISI channel[6]
[ 3.199155] mxc-isi 58170000.isi: mxc_md_unregister_all unregister ISI channel[7]
[ 3.207796] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video0 (81,0)
[ 3.216346] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video1 (81,1)
[ 3.230830] Bluetooth: HCI UART driver ver 2.3
[ 3.235293] Bluetooth: HCI UART protocol H4 registered
[ 3.240442] Bluetooth: HCI UART protocol BCSP registered
[ 3.245762] Bluetooth: HCI UART protocol ATH3K registered
[ 3.251196] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.257595] Bluetooth: HCI UART protocol Broadcom registered
[ 3.263286] Bluetooth: HCI UART protocol QCA registered
[ 3.269682] sdhci: Secure Digital Host Controller Interface driver
[ 3.275877] sdhci: Copyright(c) Pierre Ossman
[ 3.280599] Synopsys Designware Multimedia Card Interface Driver
[ 3.288476] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.295838] iommu: Adding device 5b010000.usdhc to group 2
[ 3.301790] mmc0: CQHCI version 5.10
[ 3.338900] mmc0: SDHCI controller on 5b010000.usdhc [5b010000.usdhc] using ADMA
[ 3.348181] iommu: Adding device 5b020000.usdhc to group 2
[ 3.353965] mmc1: CQHCI version 5.10
[ 3.357617] sdhci-esdhc-imx 5b020000.usdhc: Got CD GPIO
[ 3.362863] sdhci-esdhc-imx 5b020000.usdhc: Got WP GPIO
[ 3.368171] sdhci-esdhc-imx 5b020000.usdhc: Linked as a consumer to regulator.2
[ 3.406535] mmc1: SDHCI controller on 5b020000.usdhc [5b020000.usdhc] using ADMA
[ 3.417210] mxc_mlb150 5b060000.mlb: 5b060000.mlb supply reg_nvcc not found, using dummy regulator
[ 3.427255] mxc_mlb150 5b060000.mlb: Linked as a consumer to regulator.0
[ 3.433974] mxc_mlb150 5b060000.mlb: enalbe regulator
[ 3.439054] mxc_mlb150 5b060000.mlb: no iram assigned, using external mem
[ 3.442604] mmc0: new HS400 MMC card at address 0001
[ 3.446550] mxc_emvsim 5a0d0000.sim0: emvsim register success
[ 3.451613] mmcblk0: mmc0:0001 R1J57L 29.1 GiB
[ 3.461717] mmcblk0boot0: mmc0:0001 R1J57L partition 1 8.00 MiB
[ 3.468228] mmcblk0boot1: mmc0:0001 R1J57L partition 2 8.00 MiB
[ 3.474216] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.474275] mmcblk0rpmb: mmc0:0001 R1J57L partition 3 4.00 MiB, chardev (236:0)
[ 3.482337] caam 31400000.caam: ERA source: device tree.
[ 3.495926] [drm] Cannot find any crtc or sizes
[ 3.497635] Alternate GPT is invalid, using primary GPT.
[ 3.501801] caam algorithms registered in /proc/crypto
[ 3.505827] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 3.512979] caam_jr 31430000.jr2: registering rng-caam
[ 3.523102] caam 31400000.caam: caam pkc algorithms registered in /proc/crypto
[ 3.531679] platform caam_sm: blkkey_ex: 8 keystore units available
[ 3.538211] caam 31400000.caam: SM test passed
[ 3.543471] usbcore: registered new interface driver usbhid
[ 3.549070] usbhid: USB HID core driver
[ 3.554212] imx8qxp_adc 5a880000.adc: Linked as a consumer to regulator.4
[ 3.563618] optee: probing for conduit method from DT.
[ 3.570854] optee: revision 3.2 (6a22e6e8)
[ 3.571028] optee: initialized driver
[ 3.586359] ***** imx8qm_acm_init *****
[ 3.613164] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 3.620149] imx-cs42888: probe of sound-cs42888 failed with error -22
[ 3.627106] imx-wm8960 sound: wm8960-hifi <-> 59050000.sai mapping ok
[ 3.633592] imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
[ 3.640648] imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> direct -> CPU-Playback
[ 3.649361] imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
[ 3.656152] imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
[ 3.664685] imx-wm8960 sound: ASoC: no DMI vendor name!
[ 3.724264] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 3.731500] mmcblk1: mmc1:59b4 USDU1 14.7 GiB
[ 3.737052] mmcblk1: p1 p2
[ 3.785651] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 59030000.spdif mapping ok
[ 3.793506] imx-spdif sound-hdmi-arc: ASoC: no DMI vendor name!
[ 3.802357] imx-cdnhdmi sound-hdmi-tx: i2s-hifi <-> 59090000.sai mapping ok
[ 3.809361] imx-cdnhdmi sound-hdmi-tx: ASoC: no DMI vendor name!
[ 3.816283] fsl-audmix 59840000.audmix: DAI FE name:HiFi-AUDMIX-FE-ai@59820000
[ 3.823558] fsl-audmix 59840000.audmix: DAI FE name:HiFi-AUDMIX-FE-ai@59830000
[ 3.830839] imx-audmix imx-audmix.0: DMA mask not set
[ 3.836186] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> 59820000.sai mapping ok
[ 3.843838] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> 59830000.sai mapping ok
[ 3.851451] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> audmix-0 mapping ok
[ 3.858721] imx-audmix imx-audmix.0: snd-soc-dummy-dai <-> audmix-1 mapping ok
[ 3.865969] imx-audmix imx-audmix.0: ASoC: no DMI vendor name!
[ 3.872919] NET: Registered protocol family 26
[ 3.877931] NET: Registered protocol family 10
[ 3.882962] Segment Routing with IPv6
[ 3.886676] NET: Registered protocol family 17
[ 3.891127] can: controller area network core (rev 20170425 abi 9)
[ 3.897422] NET: Registered protocol family 29
[ 3.901871] can: raw protocol (rev 20170425)
[ 3.906157] can: broadcast manager protocol (rev 20170425 t)
[ 3.911828] can: netlink gateway (rev 20170425) max_hops=1
[ 3.917469] Bluetooth: RFCOMM TTY layer initialized
[ 3.922366] Bluetooth: RFCOMM socket layer initialized
[ 3.927526] Bluetooth: RFCOMM ver 1.11
[ 3.931292] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.936609] Bluetooth: BNEP filters: protocol multicast
[ 3.941848] Bluetooth: BNEP socket layer initialized
[ 3.946820] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.952750] Bluetooth: HIDP socket layer initialized
[ 3.957764] lib80211: common routines for IEEE802.11 drivers
[ 3.963464] 9pnet: Installing 9P2000 support
[ 3.967794] Key type dns_resolver registered
[ 3.972643] registered taskstats version 1
[ 3.976769] Loading compiled-in X.509 certificates
[ 4.008611] imx8_cpufreq_init: cluster 0 running at freq 1200 MHz, suspend freq 1200 MHz
[ 4.017206] imx8_cpufreq_init: cluster 1 running at freq 1596 MHz, suspend freq 1596 MHz
[ 4.046320] imx_sc_rtc rtc: setting system clock to 1970-01-01 00:08:27 UTC (507)
[ 4.054210] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.063116] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.069736] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
[ 4.075344] vref_1v8: disabling
[ 4.080585] ALSA device list:
[ 4.083557] #0: wm8960-audio
[ 4.086614] #1: imx-hdmi-arc
[ 4.089675] #2: imx-audio-hdmi-tx
[ 4.093166] #3: imx-audmix
[ 4.165650] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.173813] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 4.183392] devtmpfs: mounted
[ 4.187009] Freeing unused kernel memory: 1472K
[ 4.192208] Run /sbin/init as init process
[ 4.345291] systemd[1]: System time before build time, advancing clock.
[ 4.361659] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 4.383765] systemd[1]: Detected architecture arm64.Welcome to NXP i.MX Release Distro 4.19-warrior (warrior)!
[ 4.413410] systemd[1]: Set hostname to <imx8qmmek>.
[ 4.549571] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.566937] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.736675] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.743633] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.767970] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.774837] systemd[1]: Reached target Host and Network Name Lookups.
[ 4.791905] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.798564] systemd[1]: Reached target Swap.
[ 4.816654] systemd[1]: Listening on udev Control Socket.
[ 4.832343] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.987663] galcore: loading out-of-tree module taints kernel.
[ 5.029171] Galcore version 6.4.0.228766
[ 5.089293] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 5.476241] systemd-journald[2415]: Received request to flush runtime journal from PID 1
[ 5.733958] [VPU Encoder] enable mu for core[0]
[ 5.750479] [VPU Encoder] vpu encoder core[0] firmware version is 1.2.4
[ 5.834133] cfg80211: failed to load regulatory.db
[ 5.888118] fsl-audmix 59840000.audmix: Started TDM1 needed for config propagation!
[ OK ] Started Periodic Command Scheduler.
[ 6.432991] fsl-audmix 59840000.audmix: Started TDM1 needed for config propagation!
[ 6.760811] Atheros 8031 ethernet 5b040000.ethernet-1:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=5b040000.ethernet-1:00, irq=POLL)
[ 6.775889] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.024423] switch cluster 0 cpu-freq governor to schedutil
[ 7.056081] switch cluster 1 cpu-freq governor to schedutil
Starting User Manager for UID 0...
/: fsck 20.0% complet[ 7.739185] audit: type=1006 audit(1572034392.388:2): pid=4443 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 8.039157] EXT4-fs warning (device mmcblk0p12): ext4_enable_quotas:5749: Failed to enable quota tracking (type=0, err=-3). Please run e2fsck to fix.
[ 8.052835] EXT4-fs (mmcblk0p12): mount failed
See 'systemctl status run-media-mmcblk0p12.mount' for details.NXP i.MX Release Distro 4.19-warrior imx8qmmek ttyLP0
imx8qmmek login:
Yes, IMX-LVDS-HDMI (700-29680 REV C1,) absolutely the same.
Any help would be appreciated.
Yes, I have seen that post but it has not helped.
I have used the Linux 4.19.35_1.1.0 release and fdt_file=fsl-imx8qm-mek.dtb described in the documents.
It seems all correct but has not displayed anything, and 3 monitors detected no signals.
Any help would be much appreciated.
