hello,
use imx8 ,
How does ‘app’ communicate with SCFW-PMIC,
I want to use ‘app’ to control the PMIC output,
thanks
Hi WANG
one can try pmic apis described in sect.12.20.3.1 dynamic_pmic_set_voltage()
System Controller Firmware Porting Guide (sc_fw_port.pdf) included in
SCFW Porting Kit
hello,
you provide : This approach is to develop power management in the SCFW phase,
I want to :Now that the kernel has started up and how to management power mode,
BRS
Grayli
please check power management chapter in Linux Manual
in Linux 4.19.35_1.1.0 Documentation
hello,
I still don't see what I need,
please mark Which document which page?
i want to:Control or change the output of the LDOn on PMIC after the kernel startup is complete,Change the output voltage;
i only see CMD:echo enabled > /sys/class/tty/ttymxc0/power/wakeup ;
It doesn't meet my requirements;
thanks
BRS
Grayli
hello,
use regulator_set_voltage() api function ,
The kernel's API needs to use system_call() to support APP operations,rigth?
thanks
BRS
Grayli
hi Grayli,
did you figure out how to call these api functions in kernel?
hello,
download SCFW Porting Kit,is imx-scfw-porting-kit-1.2.7.1.tar.gz
tar zxvf imx-scfw-porting-kit-1.2.7.1.tar.gz,
but no sc_fw_port.pdf.
