IMX7D ES103TC1 EINK ISSUES
2,442 次查看
cbg1
Hi FAE,
I debugging eink ES103TC1 with IMX7D. but no display. and i don't know how to find struct fb_videomode *mode. can you please give me some advise? Many Thanks.
Brian
标记 (1)
10 回复数
1,618 次查看
snehix
Do we have a solution for the problem ? If so please share
2,023 次查看
cbg1
Do you have any update?
Brian
2,023 次查看
cbg1
No.
2,023 次查看
cbg1
Dear FAE,
Any update?
Brianchen
2,023 次查看
art
Does the display show the normal picture in normal oriemtation?
2,023 次查看
cbg1
EINK Panel have display. But facing display abnormal issues when rotating 270 degree. Resolution is 1404x1872. Pls check the attach. 无标题.jpgCatch8333(09-04-09-30-05).jpg
2,023 次查看
art
Have you applied the appropriate waveform file to the driver? Please specify.
2,023 次查看
cbg1
Dear Artur,
I did. But still no display.
2,023 次查看
art
I'm still suspecting the wrong waveform file. How did you convert the original .wbf file, provided by EInk, to the .fw file, required for the i.MX7D EPD controller?
Artur
2,023 次查看
econote_vikrant
Greetings!
I am facing same issue, however I have .wbf file from Eink and .fw file (converted by NXP). I even have timing configuration of ES103TC1 but still no display on panel.
