IMX6D 3.14.52 VPU
IMX6D 3.14.52 VPU
2,397件の閲覧回数
ispsubb
产品在imx6d 3.14.52 这个版本上进行开发。我们在接收 (通过WIFI) iphone  airplay 码流时,imx6在某些场景的码流是不能解码的,表现的现象为卡屏,且不会自动恢复。附件里面有一段在imx6播放的过程中录制的一段H264的码流(附件中的Airplay.264)
这段H264码流在PC上用播放器播放正常。在IMX6 上本地通过以下两种方式播放。
一,gst-launch
gst-launch-1.0  filesrc location=/root/Airplay.264 ! h264parse ! vpudec  ! overlaysink sync=false async=false
视频的后半部分不能解码。
二,mxc_vpu_test.out
./mxc_vpu_test.out -D "-i /root/Airplay.264 -f 2 -a 60
表现异常情况更多。
Iphone airplay 中帧率不固定,最高可能到60fps 。在iphone手机横竖屏切换,或者播放iphone手机本地视频时,非常容易出现。@Qiang Li
7 返答(返信)
2,099件の閲覧回数
刘洋
I am also studying imx6d, so I can add contact information to facilitate communication. qq: 3054576366
2,103件の閲覧回数
ispsubb
Can yout tell me the command which you had tried ? And your version ?
2,103件の閲覧回数
joanxie
I used "gst-launch-1.0 playbin uri=file:///media/sda1/Airplay.264", /media/sda1/is my path, you can change to yours, the version is 3.10.17,
2,103件の閲覧回数
ispsubb
any one help me ?
2,103件の閲覧回数
joanxie
try to use the playbin, I can play it successfully, any further update, I will follow in the salesfource. you can update your status there. I've reply to you there.
2,103件の閲覧回数
ispsubb
How to play it successfully ?   which BSP ?    3.14.52 ?
2,103件の閲覧回数
joanxie
I used the older version, but you can try the command I mailed to you, any update, you can tell me here or in the saleforce.
