Hi,all
I‘m working in IMX6Q sabreasd ,kernel:3.10.17 , mxc_vpu_test.out
the question is: when change the framerate of the encode in VPU for H.264, and use storm to play the stream, and the log of framerate is corrcected , but the storm show the framerate is 30, i can't change it?
why?
thanks for you reply
have a great day!
Ricard
what framerate do you change? did you double check if your camera can support the new framerate or not? maybe some camera only can support 30,15fps.
Hi,Xie
thanks for your replay,
my camera is support 30、15fps,and when i encode h.264 in 15fps, storm still show me 30fps
by the way,I'm used yuv file to encode
mxc_vpu_test.out is for video only. no av sync. just for play using 30fps fixed rate.
mxc_vpu_test.out is not a player.
Hi,Biyong
thanks for your reply,
I just use mxc_vpu_test.out for encode, and use storm which is an app of windows to play video
have a great day
Ricahrd
