I use iMX8MP EVK and imx-yocto-L5.10.52。
first ,test openssl :
root@imx8mpevk:~# openssl speed sha256
Doing sha256 for 3s on 16 size blocks: 11536688 sha256's in 3.00s
Doing sha256 for 3s on 64 size blocks: 8664550 sha256's in 3.00s
Doing sha256 for 3s on 256 size blocks: 5114298 sha256's in 2.99s
Doing sha256 for 3s on 1024 size blocks: 1932152 sha256's in 3.00s
Doing sha256 for 3s on 8192 size blocks: 284675 sha256's in 3.00s
Doing sha256 for 3s on 16384 size blocks: 144224 sha256's in 3.00s
OpenSSL 1.1.1k 25 Mar 2021
built on: Thu Mar 25 13:28:38 2021 UTC
options:bn(64,64) rc4(char) des(int) aes(partial) blowfish(ptr)
compiler: aarch64-poky-linux-gcc -mcpu=cortex-a53 -march=armv8-a+crc+crypto -fstack-protector-strong -O2 -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map= -fdebug-prefix-map= -fdebug-prefix-map= -fdebug-prefix-map= -DOPENSSL_USE_NODELETE -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_BN_ASM_MONT -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DVPAES_ASM -DECP_NISTZ256_ASM -DPOLY1305_ASM -DNDEBUG
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes
sha256 61529.00k 184843.73k 437879.69k 659507.88k 777352.53k 787655.34k
and then, test openssl with cryptodev engine:
root@imx8mpevk:~# modprobe cryptodev
[ 151.419636] cryptodev: loading out-of-tree module taints kernel.
[ 151.420713] cryptodev: driver 1.12 loaded.
root@imx8mpevk:~# openssl engine
(devcrypto) /dev/crypto engine
(dynamic) Dynamic engine loading support
root@imx8mpevk:~# openssl speed -engine devcrypto sha256
engine "devcrypto" set.
Doing sha256 for 3s on 16 size blocks: 11536289 sha256's in 3.00s
Doing sha256 for 3s on 64 size blocks: 8664651 sha256's in 3.00s
Doing sha256 for 3s on 256 size blocks: 5114791 sha256's in 3.00s
Doing sha256 for 3s on 1024 size blocks: 1917203 sha256's in 2.99s
Doing sha256 for 3s on 8192 size blocks: 284712 sha256's in 3.00s
Doing sha256 for 3s on 16384 size blocks: 144242 sha256's in 3.00s
sha256 61526.87k 184845.89k 436462.17k 656593.94k 777453.57k 787753.64k
The test results are the same!
Why doesn't cryptodev improve the performance of openssl?
How to test caam's performance boost to openssl?
Solved! Go to Solution.
The test results show that the CPU usage drops significantly after using CAAM to accelerate OpenSSL.
1. no caam
# serial terminal
root@imx8mpevk:~# cat /proc/interrupts | grep jr
258: 3 0 0 0 GICv3 138 Level 30902000.jr
Doing sha256 for 3s on 16 size blocks: 11486709 sha256's in 3.00s
Doing sha256 for 3s on 64 size blocks: 8664294 sha256's in 3.00s
Doing sha256 for 3s on 256 size blocks: 5114777 sha256's in 2.99s
Doing sha256 for 3s on 1024 size blocks: 1930810 sha256's in 3.00s
Doing sha256 for 3s on 8192 size blocks: 284695 sha256's in 3.00s
Doing sha256 for 3s on 16384 size blocks: 144240 sha256's in 3.00s
sha256 61262.45k 184838.27k 437920.71k 659049.81k 777407.15k 787742.72k
# ssh terminal
root@imx8mpevk:~# top
top - 11:08:22 up 43 min, 3 users, load average: 0.08, 0.02, 0.01
Tasks: 211 total, 2 running, 209 sleeping, 0 stopped, 0 zombie
%Cpu0 : 0.0 us, 0.7 sy, 0.0 ni, 99.0 id, 0.0 wa, 0.0 hi, 0.3 si, 0.0 st
%Cpu1 :100.0 us, 0.0 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu2 : 0.3 us, 0.0 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu3 : 0.0 us, 0.3 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 5613.3 total, 5102.7 free, 409.3 used, 101.2 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 5092.7 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1505 root 20 0 6220 4016 3524 R 100.0 0.1 0:06.37 openssl
32 root 20 0 0 0 0 S 0.3 0.0 0:02.19 ksoftirqd/3
688 root 20 0 388608 6960 4656 S 0.3 0.1 0:17.13 netopeer2-serve
874 root 20 0 3152 2272 1796 S 0.3 0.0 0:00.20 dropbear
1504 root 20 0 5200 2824 2140 R 0.3 0.0 0:00.10 top
1 root 20 0 159664 8180 5744 S 0.0 0.1 0:03.70 systemd
2. use -engine devcrypto
# serial terminal
[ 2772.203074] cryptodev: loading out-of-tree module taints kernel.
[ 2772.204336] cryptodev: driver 1.12 loaded.
Doing sha256 for 3s on 16 size blocks: 11535971 sha256's in 3.00s
Doing sha256 for 3s on 64 size blocks: 8664262 sha256's in 3.00s
Doing sha256 for 3s on 256 size blocks: 5113400 sha256's in 3.00s
Doing sha256 for 3s on 1024 size blocks: 1916868 sha256's in 2.99s
Doing sha256 for 3s on 8192 size blocks: 284616 sha256's in 3.00s
Doing sha256 for 3s on 16384 size blocks: 144181 sha256's in 3.00s
sha256 61525.18k 184837.59k 436343.47k 656479.21k 777191.42k 787420.50k
258: 57 0 0 0 GICv3 138 Level 30902000.jr
# ssh terminal
top - 11:13:48 up 48 min, 3 users, load average: 0.40, 0.16, 0.05
Tasks: 212 total, 2 running, 210 sleeping, 0 stopped, 0 zombie
%Cpu0 : 0.0 us, 0.0 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.3 si, 0.0 st
%Cpu2 : 0.0 us, 0.3 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu3 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 5613.3 total, 5101.4 free, 410.4 used, 101.5 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 5091.6 avail Mem
1537 root 20 0 6220 4064 3580 R 99.7 0.1 0:09.49 openssl
1536 root 20 0 5204 2756 2072 R 0.7 0.0 0:00.11 top
688 root 20 0 388608 6960 4656 S 0.3 0.1 0:19.22 netopeer2-serve
1499 root 20 0 0 0 0 I 0.3 0.0 0:00.03 kworker/u8:3-events_freezable_power_
1 root 20 0 159664 8180 5744 S 0.0 0.1 0:03.71 systemd
3. use -evp
# serial terminal
root@imx8mpevk:~# openssl speed -engine devcrypto -evp sha256
Doing sha256 for 3s on 16 size blocks: 68271 sha256's in 0.39s
Doing sha256 for 3s on 64 size blocks: 44507 sha256's in 0.14s
Doing sha256 for 3s on 256 size blocks: 43450 sha256's in 0.14s
Doing sha256 for 3s on 1024 size blocks: 39230 sha256's in 0.17s
Doing sha256 for 3s on 8192 size blocks: 22280 sha256's in 0.06s
Doing sha256 for 3s on 16384 size blocks: 14771 sha256's in 0.09s
sha256 2800.86k 20346.06k 79451.43k 236303.06k 3041962.67k 2688978.49k
258: 398125 0 0 0 GICv3 138 Level 30902000.jr
# ssh terminal
top - 11:18:54 up 53 min, 3 users, load average: 0.15, 0.09, 0.04
%Cpu0 : 0.0 us, 29.9 sy, 0.0 ni, 44.5 id, 0.0 wa, 6.6 hi, 19.0 si, 0.0 st
%Cpu1 : 0.0 us, 4.3 sy, 0.0 ni, 95.0 id, 0.0 wa, 0.7 hi, 0.0 si, 0.0 st
%Cpu2 : 0.0 us, 16.3 sy, 0.0 ni, 83.0 id, 0.0 wa, 0.7 hi, 0.0 si, 0.0 st
%Cpu3 : 3.5 us, 31.0 sy, 0.0 ni, 64.1 id, 0.0 wa, 1.4 hi, 0.0 si, 0.0 st
MiB Mem : 5613.3 total, 5101.2 free, 410.6 used, 101.5 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 5091.3 avail Mem
1556 root 20 0 6220 4092 3604 R 54.2 0.1 0:04.61 openssl
517 root -51 0 0 0 0 S 19.7 0.0 0:01.22 irq/258-3090200
516 root 20 0 0 0 0 S 16.2 0.0 0:01.33 30902000.jr-eng
1557 root 20 0 5204 2716 2028 R 1.4 0.0 0:00.05 top
32 root 20 0 0 0 0 S 0.7 0.0 0:02.74 ksoftirqd/3
688 root 20 0 388608 6960 4656 S 0.7 0.1 0:21.29 netopeer2-serve
1 root 20 0 159664 8180 5744 S 0.0 0.1 0:03.72 systemd
Similar problem, also not solved
1. no caam
# serial terminal
# ssh terminal
# serial terminal
# ssh terminal
3. use -evp
# serial terminal
# ssh terminal
Hi @lishaocheng
the options should be both engine and evp, and the multi, known as jr is one, if you do not specify it.
Harvey
I have do it , The test results are strange:
Doing sha256 for 3s on 16 size blocks: 68900 sha256's in 0.23s
Doing sha256 for 3s on 64 size blocks: 44369 sha256's in 0.17s
Doing sha256 for 3s on 256 size blocks: 43580 sha256's in 0.23s
Doing sha256 for 3s on 1024 size blocks: 39242 sha256's in 0.10s
Doing sha256 for 3s on 8192 size blocks: 22048 sha256's in 0.07s
Doing sha256 for 3s on 16384 size blocks: 14753 sha256's in 0.12s
sha256 4793.04k 16703.62k 48506.43k 401838.08k 2580245.94k 2014276.27k
root@imx8mpevk:~# openssl speed -engine devcrypto -evp sha256 -elapsed
You have chosen to measure elapsed time instead of user CPU time.
Doing sha256 for 3s on 16 size blocks: 68052 sha256's in 3.00s
Doing sha256 for 3s on 64 size blocks: 45175 sha256's in 3.00s
Doing sha256 for 3s on 256 size blocks: 44212 sha256's in 3.00s
Doing sha256 for 3s on 1024 size blocks: 39164 sha256's in 3.00s
Doing sha256 for 3s on 8192 size blocks: 22221 sha256's in 3.00s
Doing sha256 for 3s on 16384 size blocks: 14788 sha256's in 3.00s
sha256 362.94k 963.73k 3772.76k 13367.98k 60678.14k 80762.20k
If I use -evp , The test results are strange:
Only a few hundred milliseconds per test。
