I tried to develop Android Application using SABRE-SD board,
and I used SD card you provide.
However, I can't connect SABRE-SD to eclipse(android application programming tool) on PC.
Can you give the information to develop the android application using SABRE-SD barod???
This tutorial from google might be helpful:
I'm software engineer and I can program Android Application.
I referenced the following document and text.
Android_Frequently_Asked_Questions.pdf
28 How do I enable developer settings on Android 4.3?
Google has hidden the developer settings in the latest version of Jelly Bean. The following steps explain how to retrieve
developer settings:
• Go to the settings menu and scroll down to "About phone." Tap it.
• Scroll down to the bottom again until you see "Build number."
• Tap it seven (7) times. After the third tap, you'll see a playful dialog that says you're four taps away from being a
developer.
• Keep on tapping, until you've got the developer settings back.
I set SABRE-SD using the guide, and I connected SABRE-SD to PC using USB OTG port.
Windows installed SABRE-SD driver, and I think this is ADB driver.
However, eclipse can't recognize SABRE-SD.
Can anybody let me know what is problem???
I found the problem.
There is my mistake.
Windows didn't find SABRE-SD USB Driver, and couldn't install the driver.
I installed SABRE-SD USB Driver using Android SDK USB Driver.
Everything is OK !!!
I run the Android Application on SABRE-SD Board using eclipse.
First you need to start ADB service.
Saurabh
