I would like to encrypt my rootfs for security purpose. currently, i don't know how to do it. Some documents or suggestion are welcome.
Thank all.
已解决! 转到解答。
Dear trongthinh,
If you plan to use DM-Crypt to encrypt your RootFS, then,The document "Root filesystem encryption using DM-Crypt" provides detailed steps to make a it.
The target was ARM64 you can adapt it to your need (Install ARM32 toolchain and compile for ARM target).
If this reply answers your question please mark it as "Correct Answer" so that other users can access it quickly.
Maro
Dear trongthinh,
Maro
I am also working on the encryption of the rootfs for an iMX6 board.
maro: you gave a link to the document"Root filesystem encryption using DM-Crypt" but that file is not accessible ==> I get a "Unauthorized" message.
Is the access voluntarily protected ? Could you tell me what I need to do to be able to download the file ?
regards
I send some topics from community to you for reference, but for detailed information about security, you need to submit the salesforce case
