Requesting for 88w8997 BT/WIFI Driver
naresh_nakka
Hi NXP,
      Requesting 88W8997 wifi/BT driver.
WIFI: Sdio interface
BT: Uart interface
Could you please provide the Driver?
Naresh.
Harvey021
Please try this link, if you still have download issue due to privilege. You can try to follow up the link(nxp-secure-access-rights-registration.pdf) to apply for access for your own ID, as I see a valid NDA signed for your company. Please be note that you need to upload NDA file during applying, TNK Sundararajan who is from you company and may help provide NDA file for upload.
Harvey
Harvey021
naresh_nakka
Hi ,
when i opened that shared link , i am getting below as
Your userId does not have sufficient privilege to proceed with download.
Naresh
naresh_nakka
Hi Harvey ,
we are using the BT chipset is 88w8997
is 88w8997 BT Driver is open source ? is it avialable at the kernel source code ?
 I have observed that hci_mrvl.c has only one compatible property (compatible = "mrvl,88w8897) and it doesnt has 88w8997 driver compatible property .so is this driver compatible for my chipset ?
please confirm me ..!!!
Thanks ,
Naresh.
