How to confirm whether i.MX6SDL ERR007110 or ERR007220 occur.
728 次查看
satoshishimoda
Senior Contributor I
Hi community,
Our partner have a question about i.MX6SDL.
Actually, their custom board does not boot from NAND only occasionally, and we doubt ERR007117 and ERR007220.
So we want to confirm whether this boot issue is cause by ERR007117 or ERR007220
Could you let me know how to confirm it?
Satoshi Shimoda
标签 (2)
618 次查看
igorpadykov
Hi Satoshi
for ERR007117 one can attach jtag and output ENFC_CLK_ROOT
on CLKO pad using register CCM_CCOSR and check signal by oscilloscope.
For ERR007220 oen can add additional FCB records using
sect.8.5.2.2 "NAND Flash Boot Flow and Boot Control Blocks (BCB)"  IMX6SDLRM
619 次查看
igorpadykov
Hi Satoshi
