Following my investigation on https://community.nxp.com/message/995605 , is it possible to assert SNVS_LPCR[TOP] by software to trigger a software power off ? I'm trying to write to it (after setting SNVS_LPCR[DP_EN]) but I never see the bit set to 1 and the poweroff never happens.
Are there special requirements to do so ? I'm at Supervisor EL1 Secure Mode (TZ) in Non-Secure Mode (SNVS, SSM_ST = 0xb)
已解决! 转到解答。
Hi Vincent,
Is this a customer board I think, right?
In this case, please make sure you have connected PMIC_ON_REQ to PMIC_PWRON. Without these connected, that patch will not work.
By default, as far I know, PMIC_ON_REQ should connect directly to SNVS_PMIC_ON_REQ.
Marius
Hi Vincent
one can look at example on
Q&A: How is mx6 PMIC_ON_REQ under SW control?
Dear igorpadykov
From what I gather from mariusviorelgrigoras-b32331's answer and the link you posted, is that I should be able to poweroff the board by writing 0x60 to SNVS_LPCR (bit TOP and DP_EN).
What can I do to check it actually works: I tried to write them both (at the same time, or DP_EN, and then TOP) and:
- I never see the bit TOP set whereas the doc says it should be set to 1 during the shutdown sequence
- My boards continues to run code without powering down
I didn't messed much with the IOMUX pads (didn't change much after u-boot's configuration) so maybe I need to change some things here so the PMIC_ON_REQ signal is correctly routed ? My goal is to power down the board, and I don't see to be able to correctly write to SNVS_LPCR. Do I need to configure something before doing this write ?
Hi Vincent,
Marius
It is a sabre lite by Boundary Devices, but I also have a Sabre SD I could test on (I'm working on the Sabre Lite at the moment). How can I check this connection ? Is it done by software or should I check the hw specs ?
Hi !
I already got a first look at this document a couple days ago but it didn't make much sense to me at the time. I'll try to understand it better before asking more information. Thank you for your time !
