I am using yocto sumo version linux kernel.
I enabled the following OTG configuation in menuconfig:
Symbol: USB_OTG [=y] x
x Type : boolean x
x Prompt: OTG support x
x Location: x
x -> Device Drivers x
x -> USB support (USB_SUPPORT [=y]) x
x (8) -> Support for Host-side USB (USB [=y]) x
x Defined at drivers/usb/core/Kconfig:44
1. What is the device file i can expect in the rootfs with the above change?
2. What are the usb device files needed for communicating with MFG/UUU tool and how do i enable that in the kernel(I see /dev/utp missing)?
Thank you,
Anush D.
