Hello Mike,
The BSP confirmed that this configuration is as intended. The reason why the Qt5 layer is taken from the master branch is to allow the upgrade to get Qt 5.15 with vulkan support. This layer was tested and should work correctly even trough it's not taken from the Zeus branch.
I hope this information helps. Thank you for pointing this out. I'm sure other Community users will ask the same question.
