I need some support around the GPU topic of the iMX8MP.
After I switched from Kernel 5.15.52 to Kernel 6.6.23 my LVDS display did not work as expect.
I recognized that the galcore kernel module did not create a device (/dev/galcore).
How can I found out why the device is not create? I tried to remove the module and insert again but this works without error messages. I searched in dmesg and journalctl but also with no success.
So what possibilities do I have to get more information?
已解决! 转到解答。
Hi I found out that I miss to enable the mix_gpu_ml node in the devicetree.
After I add the lines
&mix_gpu_ml {
status = "okay";
and reboot I have a /dev/galcore device. And now I am also able to start weston
I checked the following things:
$ strings /usr/lib/libGAL.so | grep VERSION
$VERSION$6.4.11:745085:bc7b6a2a0f$
$ strings /usr/lib/modules/6.6.23-v6.6.23-2.0.0-phy-ge2011246/updates/galcore.ko | grep VERSION
$VERSION$6.4.11:745085$
$ldconfig -p | grep libGAL.so
libGAL.so (libc6,AArch64) => /lib/libGAL.so
So the Galcore firmware (libGAL.so) and the kernel module (galcore.ko) have the same version. I can see the galcore with lsmod command.
I have a /dev/dri/card0 device but no /dev/galcore device
Which possibilities do I have to do further checks? How is the connection between LVDS and Galcore?
That's a point I will check.
You mean it is not necessary to have a device called /dev/galcore ? I thought this is mantandory for a iMX8 system with Vivante GPU.
This is a part of weston 12 output:
[12:26:48.568] libseat: session control granted
[12:26:48.571] using /dev/dri/card0
[12:26:48.571] DRM: supports atomic modesetting
[12:26:48.571] DRM: does not support GBM modifiers
[12:26:48.571] DRM: does not support async page flipping
[12:26:48.571] DRM: supports picture aspect ratio
[12:26:48.571] Loading module '/usr/lib/libweston-12/gl-renderer.so'
[ 1] Failed to open device: No such file or directory, Try again...
[ 2] Failed to open device: No such file or directory, Try again...
[ 3] Failed to open device: No such file or directory, Try again...
[ 4] Failed to open device: No such file or directory, Try again...
[ 5] _OpenDevice(1031): FATAL: Failed to open device, errno=No such file or directory.
[ 6] Failed to open device: No such file or directory, Try again...
[ 7] Failed to open device: No such file or directory, Try again...
[ 8] Failed to open device: No such file or directory, Try again...
[ 9] Failed to open device: No such file or directory, Try again...
[ 10] _OpenDevice(1031): FATAL: Failed to open device, errno=No such file or directory.
[12:26:56.585] [seatd/client.c:471] Client disconnected
I thought the "Failed to open device" messages were from a missing /dev/galcore device. How can I get more information about the missing file or directory?
&mix_gpu_ml {
status = "okay";
Can you tell me how the procedure with the vivante galcore firmare is?
The firmware is a binary blob. The kernel module loads the firmware and initialize the GPU. Is the firmware part of the kernel module (galcore.ko) or should there a .bin file in the /lib/firmware folder which is load?
