i.MX8DXL OpenDDS do_package error
已解决
跳至解决方案
1,776 次查看
cebel
I started bitbake for the Yocto Scarthgap version. I added the meta-opendds layer to my distro.
I clone the layer from the OpenDDS added the layer to my bblayers.conf file.
I added OpenDDS to my local.conf file as "IMAGE_INSTALL:append = "opendds"
However, when I start bitbake, I get the following errors in the opendds-3.29.1-r0 do_package step.
After this error, the yocto image is created but none of the subscriber or publisher example applications in opendds are added to my rootfs.
Error Logs:
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libTAO_Valuetype.so.2.5.21: opendds-dev, opendds (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/FindTopic/findtopic)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libOpenDDS_Dcps.so.3.29.1: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/FooType/libDcpsFooType.so.3.29.1)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libTAO_Valuetype.so.2.5.21: opendds-dev, opendds (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/security/IDL_Serialization/Security_IDL_Serialization)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libACE.so.6.5.21: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/ACE_wrappers/TAO/tao/PI/libTAO_PI.so.2.5.21)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libOpenDDS_Rtps.so.3.29.1: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/RtpsDurableReplay/publisher)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libTAO_PortableServer.so.2.5.21: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/ACE_wrappers/TAO/orbsvcs/ImplRepo_Service/tao_imr)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libOpenDDS_Dcps.so.3.29.1: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/Reliability/IDL/libReliability.so.3.29.1)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libOpenDDS_Dcps.so.3.29.1: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/Prst_delayed_subscriber/publisher)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libOpenDDS_Dcps.so.3.29.1: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/security/ConcurrentAuthLimit/ConcurrentAuthLimit)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libACE.so.6.5.21: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/KeyTest/IsBounded)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libTAO.so.2.5.21: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/FACE/CallbackAndReceive/Publisher/publisher)
ERROR: opendds-3.29.1-r0 do_package: opendds-dev: Multiple shlib providers for libACE.so.6.5.21: opendds, opendds-dev (used by files: /home/yocto/yocto-nxp/build-nxp/tmp/work/armv8a-poky-linux/opendds/3.29.1/packages-split/opendds-dev/usr/share/DDS_ROOT/tests/DCPS/LivelinessTimeout/publisher)
Could you please help me these errors?
Best regards.
1 解答
1,552 次查看
cebel
Hi @pengyong_zhang,
Thank you very much for your support.
I solved the OpenDDS 3.24 do_package issue in Kirkstone thanks to the GitHub issue in the link below.
Link: https://github.com/OpenDDS/meta-opendds/issues/47
Best regards.
在原帖中查看解决方案
2 回复数
1,746 次查看
pengyong_zhang
HI @cebel
This is because there are multiple shared library (shlib) providers in the opendds-dev package, which can cause file conflicts. The specific problem is that multiple library files (such as libACE.so, libOpenDDS_Dcps.so, etc.) may be provided by multiple packages, resulting in conflicts during build.
Here are some solution suggestions:
1. Check the dependencies of the OpenDDS package to ensure that there are no duplicate dependency library files.
2. Check the Yocto configuration to ensure that all library files are linked correctly.
3. Use Yocto's dependency management tool to resolve library file conflicts.
B.R
1,553 次查看
cebel
Hi @pengyong_zhang,
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-1957334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8DXL%20OpenDDS%20do_package%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%90%AF%E5%8A%A8%E4%BA%86%20Yocto%20Scarthgap%20%E7%89%88%E6%9C%AC%E7%9A%84%20bitbake%E3%80%82%E6%88%91%E5%B0%86%20meta-opendds%20%E5%B1%82%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%20OpenDDS%20%E5%85%8B%E9%9A%86%E8%AF%A5%E5%B1%82%E5%B9%B6%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%20bblayers.conf%20%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%B0%86%20OpenDDS%20%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%20local.conf%20%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E4%BD%9C%E4%B8%BA%E2%80%9CIMAGE_INSTALL%3Aappend%20%3D%E2%80%9Dopendds%E2%80%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%90%AF%E5%8A%A8%20bitbake%20%E6%97%B6%EF%BC%8C%E5%9C%A8%3CSTRONG%3Eopendds-3.29.1-r0%20do_package%3C%2FSTRONG%3E%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%AD%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%E5%90%8E%EF%BC%8Cyocto%20%E6%98%A0%E5%83%8F%E5%B7%B2%E5%88%9B%E5%BB%BA%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E8%AE%A2%E6%88%B7%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%88%96%E8%80%85%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E5%87%BA%E7%89%88%E5%95%86%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eopendds%20%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%20rootfs%20%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9A%3CBR%20%2F%3E%3C%2FSTRONG%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibTAO_Valuetype.so.2.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds-dev%E3%80%81opendds%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FFindTopic%2Ffindtopic%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibOpenDDS_Dcps.so.3.29.1%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FFooType%2FlibDcpsFooType.so.3.29.1%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibTAO_Valuetype.so.2.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds-dev%E3%80%81opendds%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2Fsecurity%2FIDL_Serialization%2FSecurity_IDL_Serialization%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibACE.so.6.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2FACE_wrappers%2FTAO%2Ftao%2FPI%2FlibTAO_PI.so.2.5.21%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibOpenDDS_Rtps.so.3.29.1%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FRtpsDurableReplay%2Fpublisher%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibTAO_PortableServer.so.2.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2FACE_wrappers%2FTAO%2Forbsvcs%2FImplRepo_Service%2Ftao_imr%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibOpenDDS_Dcps.so.3.29.1%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FReliability%2FIDL%2FlibReliability.so.3.29.1%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibOpenDDS_Dcps.so.3.29.1%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FPrst_delayed_subscriber%2Fpublisher%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibOpenDDS_Dcps.so.3.29.1%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2Fsecurity%2FConcurrentAuthLimit%2FConcurrentAuthLimit%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibACE.so.6.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FKeyTest%2FIsBounded%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibTAO.so.2.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FFACE%2FCallbackAndReceive%2FPublisher%2Fpublisher%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9Aopendds-3.29.1-r0%20do_package%EF%BC%9Aopendds-dev%EF%BC%9AlibACE.so.6.5.21%20%E7%9A%84%E5%A4%9A%E4%B8%AA%20shlib%20%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%9Aopendds%E3%80%81opendds-dev%EF%BC%88%E6%96%87%E4%BB%B6%E4%BD%BF%E7%94%A8%EF%BC%9A%2Fhome%2Fyocto%2Fyocto-nxp%2Fbuild-nxp%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fopendds%2F3.29.1%2Fpackages-split%2Fopendds-dev%2Fusr%2Fshare%2FDDS_ROOT%2Ftests%2FDCPS%2FLivelinessTimeout%2Fpublisher%EF%BC%89%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1957334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Ai.MX8DXL%20OpenDDS%20do_package%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%B8%8B%E9%9D%A2%E9%93%BE%E6%8E%A5%E4%B8%AD%E7%9A%84%20GitHub%20%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%20Kirkstone%20%E4%B8%AD%E7%9A%84%20OpenDDS%203.24%20do_package%20%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3ELink%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOpenDDS%2Fmeta-opendds%2Fissues%2F47%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FOpenDDS%2Fmeta-opendds%2Fissues%2F47%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Ai.MX8DXL%20OpenDDS%20do_package%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F240792%22%20target%3D%22_blank%22%3E%40cebel%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%20opendds-dev%20%E5%8C%85%E4%B8%AD%E6%9C%89%E5%A4%9A%E4%B8%AA%E5%85%B1%E4%BA%AB%E5%BA%93%EF%BC%88shlib%EF%BC%89%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%96%87%E4%BB%B6%E5%86%B2%E7%AA%81%E3%80%82%E5%85%B7%E4%BD%93%E9%97%AE%E9%A2%98%E6%98%AF%E5%A4%9A%E4%B8%AA%E5%BA%93%E6%96%87%E4%BB%B6%EF%BC%88%E4%BE%8B%E5%A6%82%20libACE.so%EF%BC%8ClibOpenDDS_Dcps.so%EF%BC%8C%E7%AD%89%EF%BC%89%E5%8F%AF%E8%83%BD%E7%94%B1%E5%A4%9A%E4%B8%AA%E5%8C%85%E6%8F%90%E4%BE%9B%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%AF%BC%E8%87%B4%E6%9E%84%E5%BB%BA%E6%9C%9F%E9%97%B4%E5%8F%91%E7%94%9F%E5%86%B2%E7%AA%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%80%E4%BA%9B%E8%A7%A3%E5%86%B3%E5%BB%BA%E8%AE%AE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1.%E6%A3%80%E6%9F%A5OpenDDS%E5%8C%85%E7%9A%84%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E7%A1%AE%E4%BF%9D%E6%B2%A1%E6%9C%89%E9%87%8D%E5%A4%8D%E7%9A%84%E4%BE%9D%E8%B5%96%E5%BA%93%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%202.%E6%A3%80%E6%9F%A5Yocto%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%A1%AE%E4%BF%9D%E6%89%80%E6%9C%89%E5%BA%93%E6%96%87%E4%BB%B6%E9%83%BD%E6%AD%A3%E7%A1%AE%E9%93%BE%E6%8E%A5%E3%80%82%3CBR%20%2F%3E3.%E4%BD%BF%E7%94%A8Yocto%E7%9A%84%E4%BE%9D%E8%B5%96%E7%AE%A1%E7%90%86%E5%B7%A5%E5%85%B7%E8%A7%A3%E5%86%B3%E5%BA%93%E6%96%87%E4%BB%B6%E5%86%B2%E7%AA%81%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
