I'm using external watchdog MAX6751 for imx6q board and i need to trigger it in u-boot, otherwise system would reset. The reset time is about 1 sec.
I've added initialization of GPIO PAD to the board support code and function hw_watchdog_reset(). When i enable CONFIG_HW_WATCHDOG and compile u-boot, it does not load at all. When i disable CONFIG_HW_WATCHSOG, everything boots fine.
Did anybody have any issues of auto-triggering watchdogs in u-boot?
Thanks a lot
Konstantyn
Hi Igor, thank you very much. I'll ask this question on u-boot forum. I was just hoping somebody from NXP community had the same problem and it is imx6 related.
Konstantyn
Hi Konstantyn
nxp uboot does not use external wdog and since this is not imx specific
question it may be posted on uboot mail list
