Hi, what ble stack was used for bluetooth examples on RT 1060? I've been told that it is ethermind being used, but it appears to me like it is edgefast. Could you help?
Solved! Go to Solution.
EdgeFast BT PAL uses the ethermind stack as lower layer.
Have a nice day, Daniel
Hi @AngeloMbed ,
My name is Daniel and I will be happy to help you.
The RT1060 SDK is using EdgeFast BT.
Best regards, Daniel.
Hi Daniel,
Thanks for helping out.
I’m seeing both ethermind and edgefast, could you help me understand what edgefast’s role is in ethermind stack, or how do the two relate?
thanks!
