I'm trying to build Android 4.4.2 to sabresd board but I'm getting the following error.
No private recovery resources for TARGET_DEVICE sabresd_6dq
make: *** No rule to make target `out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/libwpa_client_intermediates/export_includes', needed by `out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/libhardware_legacy_intermediates/import_includes'. Stop.
I've seen similar issues for Android Jelly Bean building but seems like the parameters for Android Kit Kat are very different. Could you give me some help to solve this issue?
解決済! 解決策の投稿を見る。
Hi Sergio,
I've set up a new environment from scratch and worked around this issue. I'm actually using ubuntu 12.04 and could generate the android files pretty well.
Thanks man.
hmm... I actually haven't encountered this error before...
Alan, you did download this BSP from our site right?, did you do any modifications to it?... which ubuntu version are you using as host machine? are you following the android user guide? including the initializing steps? : Initializing a Build Environment | Android Developers
Hi Sergio,
Thanks man.
HI Alan
i meet the same issue, too.
Before add the Bcmdhd wifi into Android , everything is ok(build bootimage ,build system images)
And could you tell me how to solved it ? "Set up a new environment from scratch and worked around".
BRs,
Warren
SergioSolis, would you have any experience with this error?
