Dear all,
I want to know the eFuse program procedure for i.MX6UL.
I am looking for the document such as the application note of i.MX25.
http://cache.nxp.com/files/dsp/doc/app_note/AN3682.pdf
- 4 Fuse Programming Procedure(P.17)
- 6 Sample Code(P.18-)
Is there such a document for i.MX6UL?
Yuuki
I program the fuses few day ago... Good starting point is to read IMXULRM (fusemap, system boot, and on-chip OTP Controller) and AN4581
then you can program fuse from u-boot command prompt: fuse prog <bank> <word> <value> - this is permanent.
(how to build u-boot - you can find in i.MX6UL hab_status )
you can also normal boot into kernel, go to /sys/fsl_opt and echo <value> > HW_OCOTP_...
Robert
It is recommended to use NXP U-boot for fuse operations.
Yuri.
