DRAM combination for i.MX8M QUAD
666 次查看
Kazuma_Sasaki
Senior Contributor I
We would like to use 12Gb DDR3L memory. Please let me confirm DRAM combination for i.MX8M QUAD..
I am thinking about following combination. Which case is available for i.MX8M QUAD?
Case.1 = Total 12Gb
i.MX8M QUAD <-DDRC Ch0-> 4Gb, x8bit  x 2pcs
                        <-DDRC Ch1-> 4Gb, x16bit x 1pcs
Case.2 = Total 12Gb
                        <-DDRC Ch1-> 2Gb, x8bit x 2pcs
Case.3 = Total 12Gb
i.MX8M QUAD <-DDRC Ch0-> 8Gb, x16bit  x 1pcs
Kazuma Sasaki.
标记 (1)
587 次查看
art
The Case 1 you've listed is not convenient in terms of PCB routing. The Case 2 and Case 3 are possible. Also, please note that better is to use the whole 32-bit DDR bus width to increase the memory bandwidth.
Artur
588 次查看
art
Artur
